[DesignModeler] Continue sketching in another plane/direction.
Old   July 26, 2016, 06:39
Default Continue sketching in another plane/direction.
masands is on a distinguished road
This should be an easy one for you folks experienced with DesignModeller. I come from an ICEM background so this is very easy to do there.
Basically, I need to sketch out a complex sweeping path for a pipe system. It twists and turns in all planes. For example, 10m along the X direction, then 5m up in the Y direction and then changes to Z direction and travels for another 15m.
Now, I cannot for the life of me figure out how I continue sketching from a XY sketch to a ZX sketch (if you know what I mean). I cannot select the end point of the XY sketch in the ZX plane to continue drawing my profile.
In ICEM, I simply enter construction points at a XYZ location and connect them up using lines. I can't seem to figure out how to do that here either so I'm just using lines right now.
Any help would be appreciated.
Thanks!
masands is offline   Reply With Quote
Old   July 28, 2016, 02:01
Kapi is on a distinguished road
umm!! i dont think you can do that.
You can create seperate geometry and bring it together tho!
Kapi is offline   Reply With Quote
Old   November 8, 2022, 02:07
A.Randhawa
AslamRandhawa is on a distinguished road
Thanks!
Hi, U can do this in the same way in DM too. Construction points in Sketch mode will be marked in One Plane only (ie. Same Plane), but, in Modeling mode, U can mark the Construction point in all three planes by adjusting Point Coordinates. Process is as under:
1. Pick Construction (select the Point in Tree Outline).
2. Go to Details Views (Below the Model) and Select, Construction Point against Type. Select Manual Input against Definition. Enter the values of all three coordinates. Lastly, Join the required Points and Enjoy.
AslamRandhawa is offline   Reply With Quote
A algorithm problem meets in the FTC3D code liaoyun0126 Main CFD Forum 0 September 14, 2015 10:24
command TUI / Scheme for stop and continue calculate rayolau FLUENT 1 May 13, 2013 10:20
Problem with sketching don't see what i'm sketching... rosica2136 CFX 1 December 13, 2012 16:31
2D CFD code using SIMPLE algorithm bfan Main CFD Forum 3 June 22, 2002 22:01
EULER-Forward-Method freak Main CFD Forum 4 June 12, 2001 09:19
