[ANSYS Meshing] Cyclic Symmetry -Meshing Topology Error
Old   July 17, 2023, 10:40
Default Cyclic Symmetry with open joints/gaps
Anonymous
praveenray is on a distinguished road
Do cyclic symmetry works with open joints and the contacts between them being bonded?
Furthermore, do the hoop continuity stress affects both the components due to the bonded contacts(as it behaves as a continuous component) in Cyclic symmetry. Whether the stiffness of the 2 parts will be affected in simulation due to the bonded contacts in cyclic symmetry, even if it is not joined in the real working of the component.
praveenray is offline   Reply With Quote
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
[swak4Foam] installing funkySetFields igo OpenFOAM Community Contributions 1 November 20, 2012 20:16
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
