[DesignModeler] Fill a solid square with hollow spheres.
Old   July 27, 2023, 16:15
Default Fill a solid square with hollow spheres.
Alim
aalim is on a distinguished road
Hi. I am a complete beginner at Ansys. I want to fill a solid square with hollow spheres. The patterning doesn't work here. I even tried doing each hollow sphere manually(Primitive->Sphere->Cut Material), but that doesn't work. What would be the effective approach to filling a solid square with hollow spheres?
aalim is offline   Reply With Quote
Old   July 31, 2023, 05:32
Smile Create spheres and subtract using boolean
Anonymous
leodan is on a distinguished road
Create spheres as frozen bodies apart from the square block (solid).
After patterning the spheres according to your requirement, use boolean subtract to remove the volume occupied by the sphere from the square block.
You will get hollow spheres in a single solid square block.
leodan is offline   Reply With Quote
Edge removal after solid fill hole python script function akkidivate ANSA 1 October 19, 2020 05:57
chemical reaction involving gaseous reactants and solid product sara137 Fluent Multiphase 0 June 21, 2020 05:26
[swak4Foam] mass conservation of solid phase violated when using groovyBC with twoPhaseEulerFoam xpqiu OpenFOAM Community Contributions 8 June 17, 2015 02:08
Immersed solid, vs solid-fluid interaction to determine forces on a submerged solid amrbekhit CFX 0 January 8, 2015 16:39
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
