August 3, 2023, 08:19 |
Association problem meshing coil pipe
Assem
Rep Power: 4 |
I am trying to mesh a coil pipe as in figure
I always face this mesh problem like there is a conflict in association like in figure attached I tried to dis associate and then re associate but it did not work could any one help please? |
August 4, 2023, 01:12 |
Youtube tutorial available for the same
Anonymous
Rep Power: 3 |
There is a Youtube video available already on a similar geometry and meshing where they have explained the association part. The mesh seems reasonable, so you can follow the same.
August 4, 2023, 09:19 |
Gert-Jan
Rep Power: 27 |
Alternatively, only mesh the T-junction and then extrude the mesh on the ends of the T-junction along the curve/spline of the coil. Much easier.......
To extrude a mesh look for the second or third Icon in Edit Mesh-menu |
[GAMBIT] Problem in meshing a pipe within a cylinder | l14766 | ANSYS Meshing & Geometry | 7 | May 14, 2013 17:24 |
pipe flow problem | RodriguezFatz | FLUENT | 2 | August 9, 2011 07:59 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
GAMBIT meshing problem | Gauthier Lambert | Main CFD Forum | 1 | August 3, 2000 09:22 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
