[ICEM] How to preserve edge grading of blocks during rotation? |
August 7, 2023, 08:40 |
ishan
Rep Power: 8 |
I have an axisymmetric model for which I am generating 2D blocks and specifying the edge gradings in ICEM. I am converting these 2D blocks to 3D by rotating them through the dedicated option of Create Block> 2D to 3D> Rotation. The major problem with this is that the edge gradings and linked edges that I have generated in 2D are not carried over to 3D. This is creating an issue because now, I have to re-link and re-grade the edges for the rotate 3D model. This is extremely time consuming. I specifically went with the rotation approach because of the following reasons: 1)grading in 3D is really complicated for my setup as it has many blocks. 2) i want to merge an Ogrid topology with these rotated blocks because there is no direct way we can generate O Grid in a quarter-3D model. 3) I am limited by the number of processors ICEM can use so it also limits my iterative process of mesh generation I posted this issue in ANSYS Learning Forum but did not get any satisfactory reply from them. |
icem 2d, icem 3d |
Actuator disk model | audrich | FLUENT | 0 | September 21, 2009 07:06 |
Where's the singularity/mesh flaw? | audrich | FLUENT | 3 | August 4, 2009 01:07 |
[blockMesh] Grading other than simple and edge | titio | OpenFOAM Meshing & Mesh Conversion | 0 | March 5, 2008 11:50 |
[Commercial meshers] Star mesh import problem | chris1980 | OpenFOAM Meshing & Mesh Conversion | 20 | May 8, 2006 01:07 |
