(ICEM)Negative volumes instead of thiner layer
Old   August 10, 2009, 06:11
Cool (ICEM)Negative volumes instead of thiner layer
cbr
cbr is on a distinguished road
I'm preparing 2-D mesh for a wing in ICEM
I need to 7-times decrease thickness of first near-wall layer, because max(y+) is 7 in my result file. But I'm getting negative volume when I set new thickness.
Please help me to fix it, thanks in advance!
cbr is offline   Reply With Quote
Old   August 10, 2009, 14:46
Default Kate Moss Thin
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
There is a known defect (see the release guide) about the quality metrics sometimes calling thin hexas inverted…
If your solver is structured, do the checks in the blocking tab, and if the very thin elements look (visually) ok, proceed to your solver and check it there.
If your solver is unstructured, do the checks on the unstructured mesh (Edit Mesh tab)...
On the other hand, you could actually be having a problem with the mesh…
If so, then I am guessing that you probably have a slight misalignment of parts (curves not aligned with surfaces to the same tolerance as your first cell height) and the mesh is trying to follow too closely. In certain situations, refining the mesh below the scale of the geometry quality can invert the boundary layer in the last element when projection changes from one entity to the other. If that is what you find (visually), setting projection limit can really help.
PSYMN is offline   Reply With Quote
Old   August 19, 2009, 03:35
cbr
Thanks Simon,
I have invented also another method- scale initial geometry 10 times (for example), create mesh for scaled geometry, open the mesh in pre and scale mesh 0.1 to initial size. Correct volume of thin elements keeps at that transformation in CFX-pre
Old   August 20, 2009, 08:45
cbr
Everithing great is simple
another one solution of this problem is restart ICEM
Old   August 20, 2009, 17:35
Default Reboot the shuttle...
PSYMN's Avatar
Simon Pereira
Do you recall that time a few years back when the Space Shuttles computers were acting up and there was a tense 15 minutes while the astronauts had to sit in the dark as the orbiters computers were rebooted? There was some worry about if they would reboot properly, but they did, and then everything was fine.
I often think that as I reboot anything… If it was a good enough solution for NASA…
Old   August 21, 2009, 04:26
cbr
I'm almost astronaut then, hehe
Old   October 18, 2023, 16:37
@Arash is on a distinguished road
Hi Dear cbr,
I have exactly the same problem as you. By adjusting the thickness of the first layer near the wall to reach Y+ = 1, negative volume is created for me.
How can I fix this problem?
Thanks in advance.
@Arash is offline   Reply With Quote
[Gmsh] Default Faces on Boundary Layer axel OpenFOAM Meshing & Mesh Conversion 8 February 17, 2011 07:47
To thin boundary layer? Luk CFX 3 February 27, 2009 03:22
errors Fahad Main CFD Forum 0 March 23, 2004 13:20
Boundary Layer Flow Paradox Wen Long Main CFD Forum 3 September 24, 2002 08:47
union of volumes CHUBBY FLUENT 2 May 4, 2001 06:31
