[ANSYS Meshing] Structured 3D mesh
Old   January 24, 2024, 19:51
Red face Structured 3D mesh
Tomás Ortiz
tomasOrt is on a distinguished road
Hello to everyone.
Currently, I am trying to make an structured mesh in a subdomain for carrying out a sliding mesh simulation of a drone rotor in forward flight.
I found a project where they did the grid using ICEM and block meshing. However, I lack of knowledge on ICEM CFD meshing so I tried to split the geometry and then to proceed with edge sizing and face meshing. It seemed to be working at least until I tried to refine it. Face meshing and inflation layers are incompatible so I tried to introduce Bias in order to capture the boundary layer and to ensure a low WallY+. Neverthless, I cannot mesh if I increase to much the partitions in the edges that fix the layers normal to the airfoil or if I set a bigger bias growing factor. The smallest cells I can obtain is by setting 80 partitions in the edge and a Growing factor of 5. However, regarding my estimations that will not be enough for ensuring low wallY+ treatment. (chord 0.02m, ground level atmospheric conditions and air as a fluid. 3500 rpm with 0.2m of radios and 10m/s of forward speed... Re at the tip around 150k).
Iwill attach images of the mesh and also the grid I founded generated with ICEM. I have pointed out the edges where I cannot reduce the size of the cells anymore.
If anyone has a suggestion of how I could reduce the first cell height even more with the current mesh or a good tutorial for ICEM that could be helpfull for the grid generation, I would really appreciate it.
tomasOrt is offline   Reply With Quote
bias, fluent, icem 3d blocking, meshing
[ICEM] Structured and unstructured mesh in ICEM Weiqiang Liu ANSYS Meshing & Geometry 4 May 13, 2020 10:37
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 11:45
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
