May 6, 2024, 06:32 |
PyTurbogrid NDF File Format
Daniel
Rep Power: 9 |
I am currently trying to dig into PyAnsys, especially PyTurbogrid. Currently, the API does not support direct import of the usual .curve files. It will be implicitly stated in an .inf file. But, loading the curve files through an .inf file, limitations of the API are present. Therefore, I would need to use the Multi_blade_row API, which needs an NDF file. I looked everywhere, but nowhere is a good explanation how this file should look for Turbogrid, in order to specify my .curve files or other blade parameters. Has anyone an example file or any hints how I could create such an .NDF file? Thank you and kind regards Daniel |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 08:46 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 21:03 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
