July 23, 2009, 05:09 |
ICEM and CYLINDRICAL CORDINATE SYSTEM
Hamoudi djamel
Hi Everybody,
I have a problem,I have 2D simulation i build my geometry and my Mesh in ICEM-CFD, then I export them to Star-cd, all thing is well in the same coordinate system cartesian to cartesian coordinate system. But when i build my geometry and do my Mesh (ICEM-CFD) in cylindrical coordinate system in (r,theta,z) then i have my geometry in (y,z) plane, so for the velocities the radial velocity U(r) is in -------- y direction and U (theta) tangential velocity is in --------x direction and U(z) is in ------------------------------- z direction ---------------------------------------------------------------- after that i export my Mesh to Star-CD in boundary condition at the inlet part i change the coordinate system from cartesian to cylindrical from number 1 to number 2 from ( x,y,z) to (r,theta,z) then Star-CD consider that the radial velocity U(r) is --------------------- in x direction U (theta) is ----------------in y direction U(z) is ---------------------in z direction ------------------------------------------------------------------- so you can observe that there is a confusion in the axis from the initial case I try to do changement of the velocities to the axis I put U(r) in y direction and U (theta) in x direction then my simulation did not convergt i have got a bad convergence ---------------------------------------------------------------------- I am in waiting for your suggestion Thank you very much for you |
July 23, 2009, 06:37 |
CFX and Cylindrical Coordinate
Hamoudi djamel
Hi Everybody,
July 23, 2009, 07:48 |
Rep Power: 143 |
So won't a simple rotation fix it up?
Glenn |
July 23, 2009, 11:41 |
CFX and CYLINDRICAL CORDINATE SYSTEM
Hamoudi djamel
Hi Everybody,
I have a problem, I have 2D simulation i build my geometry and my Mesh in ICEM-CFD, then I export them to Star-cd, all thing is well in the same coordinate system cartesian to cartesian coordinate system. But when i build my geometry and do my Mesh (ICEM-CFD) in cylindrical coordinate system in (r,theta,z) then i have my geometry in (y,z) plane, so for the velocities the radial velocity U(r) is in -------- y direction and U (theta) tangential velocity is in --------x direction and U(z) is in ------------------------------- z direction ---------------------------------------------------------------- after that i export my Mesh to Star-CD in boundary condition at the inlet part i change the coordinate system from cartesian to cylindrical from number 1 to number 2 from ( x,y,z) to (r,theta,z) then Star-CD consider that the radial velocity U(r) is --------------------- in x direction U (theta) is ----------------in y direction U(z) is ---------------------in z direction ------------------------------------------------------------------- so you can observe that there is a confusion in the axis from the initial case I try to do changement of the velocities to the axis I put U(r) in y direction and U (theta) in x direction then my simulation did not convergt i have got a bad convergence ---------------------------------------------------------------------- I am in waiting for your suggestion ** I try to do all rotation of the plane but there is no changement in results *** Thank you very much for you |
July 23, 2009, 11:43 |
Hamoudi djamel
Hi Everybody,
CFX and cylindrical coordinates | VSB | CFX | 16 | December 10, 2019 08:53 |
Design Modeler to ICEM..... | Joe | CFX | 0 | January 24, 2008 03:39 |
Extrude mesh in ICEM CFD | Susan | CFX | 2 | November 5, 2007 17:10 |
