September 17, 2009, 08:20 |
ICEM Edge Params Bunching laws
Tyler Sloss
I am trying to make an automated front end for some blocking based grids I am making in icem, because I have to do a lot of them, and want to make it so people not familiar with icem can make grids. I want to be able to update the number of nodes to use on certain edges based on their length, but have been unable to figure out how the bi-geometric bunching law works. Thank you for any incite or help.
October 16, 2009, 09:33 |
Search the Help
Simon Pereira
Rep Power: 47 |
Look in the help... You can type Bigeometric into the search...
Look under Bunching laws for the description... Many of the other laws give the equations, but not this one. Bunching Laws BiGeometric The default bunching law. The two initial heights and ratios define parabolas in a coordinate system where the number of node points is the X-axis and the cumulative distance along the edge is the Y-axis. The parabolas are truncated where their tangent lines are identical; the spacing is linear between these points. If there are not enough nodal points to form this linear segment, a hyperbolic law is used and the ratios are ignored. |
August 21, 2011, 15:31 |
Hello!
I'm having the same trouble. For a parametrisation i also need information on the Bigeometric bunching law. But i find the help info somewhat incomplete. How exactly do the spacings and ratios define the parabolas? My first guess would be: The forumula for a parabola is f(x)=a*x^b with a=Spacing and b=ratio. Is this correct? I really need the correct definition. Thank you for help! |
September 13, 2011, 15:45 |
Yesterday, I had the same problem.
It´s not so difficult. BiGeometric distribution use for the initial and end bunching law two parabol-functions: y(x)=a+bx+cx². Using initial and end height and ratios, you can define this two parabolas. The second target is to know where both parabols have the same tangent. You can express this using two ecuactions, and getting the start and end point where to distribute the cells uniformly. Check the definition and think about it. |
July 14, 2014, 08:43 |
i know this topic was discussed long time before, but i do not understand what you mean exactly.
if i have the parabol function: y(x)=a+bx+cx² what are the variables a,b,c ? if i have two functions i become 6 unknown variables ... however 4 variables are discussed (spacing 1 and 2; ratio 1 and 2) i'm really confused at the moment ... kindly help |
May 28, 2020, 13:04 |
Are you sure BiGeometric distribution use for the initial and end bunching law two pa
#6 | |
Rep Power: 9 |
Are you sure BiGeometric distribution use for the initial and end bunching law two parabol-functions: y(x)=a+bx+cx²? |
icem |
Where's the singularity/mesh flaw? | audrich | FLUENT | 3 | August 4, 2009 01:07 |
ICEM - mesh near wing trailing edge | Joao Lourenco | CFX | 5 | August 30, 2007 17:20 |
ICEM Extrude faces - Edge params. | Santiago Orrego. | CFX | 0 | June 19, 2007 12:08 |
[Commercial meshers] Star mesh import problem | chris1980 | OpenFOAM Meshing & Mesh Conversion | 20 | May 8, 2006 01:07 |
