geometry definition
Old   January 25, 2010, 13:02
Default geometry definition
antonio is on a distinguished road
Hi all
I want to create a model composed of various surfaces. At the present stage I need to define something like a parable with base equal to 4.61 mm and "height" of 4 mm. How can I define this type of geometry (I have tried to see in tutorials examples but i did not saw an example of this type of geometry)?
Thanks for your recommendations.
antonio is offline   Reply With Quote
Old   January 26, 2010, 00:57
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
which software?
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   January 26, 2010, 04:05
Hi Max:
At the present moment I´m using the design modeler of ANSYS version 12.0.
Cheers
Old   February 3, 2010, 09:51
mic
mic is on a distinguished road
The Ansys modeler works like a CAD system, you have to sketch your geometry and than create the volume with the "extrude, revolve, etc" tools. If you're familiar with a cad tool you can easily use it and than import your model in the design modeler.
mic is offline   Reply With Quote
Old   February 3, 2010, 10:52
Dear mic:
Thanks a lot for your comments. I have already solved my problem.
Regards
[ICEM] O-grid around wing geometry Anorky ANSYS Meshing & Geometry 15 November 27, 2017 13:43
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 08:17
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
Mixing plane geometry definition Hbet FLUENT 0 January 18, 2002 07:16
volute geometry definition Derrik Mazzer CFX 2 May 15, 2001 08:20
