[ICEM] Periodic compressor geom&mesh
Old   February 17, 2010, 07:39
Thumbs up Periodic compressor geom&mesh
Attesz's Avatar
Attesz
Attesz is an unknown quantity at this point
Hi all,
I'm doing a centrifugal compressor simulation. To speed up the simulation, I want to use only a blade passage instead of the whole geometry. To get this, I have to slice the geom to a periodic piece. What is the recommend way?
1. Slice between the blades, so I get a geometry bounded by periodic boundary conditions with a blade in the middle, or
2. Slice at the centroid of the blade, so I get a clear blade passage, bounded by blade walls.
I found examples for the type 1., but the second one seems to be good too.
Thanks for any advice,
Attesz
Attesz is offline   Reply With Quote
Old   February 22, 2010, 12:06
Default Tip Gap?
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Both ways have merit…
The rule of thumb I generally use has to do with the tip gap…
If I have no tip gap, then I tend to model the passage. It gives me more freedom from periodicity constraints because only the flow ahead of and behind the blade needs to be periodic. The space between is very forgiving and I can more easily all sorts of interesting configurations (y-block, etc) for high lift blades because I don’t need to keep the element count the same along the blade.
On the other hand, If I must model the tip gap, then I model the blade (with periodicity between blades). This allows me to take advantage of the periodic smoother which will have much more flexibility to adjust the mesh between the blades because there is more room to move.
PSYMN is offline   Reply With Quote
Old   March 3, 2010, 05:44
Attesz's Avatar
Attesz
Thanks for your answer, I chose the first type, because of the tip gap.
Best Regards,
Attesz
Old   March 4, 2010, 09:18
Talking periodic mesh
Attesz's Avatar
Attesz
I want to use 1:1 periodic interface in centrifugal compressor. Could you tell me the instructions, how to create a 1:1 mesh on the periodic interface surfaces? I'm using ICEM V11 tetra.
Thank you very much,
Attesz
Old   March 4, 2010, 09:38
Wink I get asked this question periodically, but you could just look in the help
PSYMN's Avatar
Simon Pereira
Type periodic into the help search engine I shouldn't make it so easy that you don't just look in the help first.
There are tutorials and documentation.
But it is easy to do. Just go into the Global Mesh params (first button on the mesh tab), and then select the Global Periodicity settings (last ICON in the Global Params DEZ). Once inside, it should be pretty clear.
Tetra uses this as it is,
Hexa uses this as a starting point (to set the periodicity settings), but then you still need to "Make Verts Periodic" in the blocking tab.
Old   March 5, 2010, 12:53
Attesz's Avatar
Attesz
Yes, I've found that in help, there was not too much information I thought it's not so easy as you write it. However, thanks!
Regards,
Attesz
Old   March 5, 2010, 16:58
PSYMN's Avatar
Simon Pereira
I think users think it will be difficult because they are expecting to need to select periodic faces, etc. but all it wants is the angle of rotation and a point and vector for the axis... It figures out the rest.
I usually do still put my periodic faces into different parts, but that is just for the BOCOs or Periodicity check and is not required by the mesher.
Old   March 11, 2010, 06:09
Attesz's Avatar
Attesz
Thanks Psymn for your answer, it's really simple. But I have 3 domains in geometry, and they are all periodic, but have all different periodic angle: 72deg, 60deg and 120deg. In this case, how can I set the periodicity for each domain, or is it impossible?
Thanks again!
Regards,
Attesz
Old   March 11, 2010, 19:09
Default Sorry, its a global function.
PSYMN's Avatar
Simon Pereira
Nope, because the periodic setting is global, only one section can be done at a time...
We are thinking about adding a "match face" command that would essentially allow you to set identical mesh on any pair of surfaces even if they aren't periodic, but we are not there yet.
Old   March 11, 2010, 19:12
Default Work around.
PSYMN's Avatar
Simon Pereira
Work around...
If you want to trick it, you can mesh it without periodicty, then copy/rotate the surface mesh from one periodic face to the other... Then run the merge meshes => Make Consistent option...
This will make the volume mesh consistent with the new volume mesh...
If you have some experience with ICEM CFD mesh editing, it is pretty doable, but if you are new... Then I suggest you just break the model up into three sections and run periodic on each one.
Simon
Old   March 12, 2010, 10:33
Attesz's Avatar
Attesz
The first option that you suggested, sounds better. I've a bit more than half-year experience in tet-meshing with ICEM, so I think I can make it. Otherwise, I will do the other way..
Thank you for your kind assistance
Best regards,
Attesz
Old   April 7, 2010, 09:50
Attesz's Avatar
Attesz
Hi all,
I have a little problem in Icem v12.1. Previously I used quick delanuay volume mesh type in tetra mesh. Now I try to change to advancing front, but this method removes the surface mesh on the interfaces. I have a compressor stage, and between the stages there are interfaces, as a single planar surface. Should I use duplicate surfaces? Why removes this method the surface mesh from the interfaces?
Regards,
Attesz
Old   April 21, 2010, 18:10
Default Try Delaunay with TGlib AF in 12.1
  #13
PSYMN's Avatar
Simon Pereira
The Advancing front mesher is my least favorite. It has lots of issues like this. If you have access to 12.1, try the Delaunay with AF (Advancing Front) TGlib (TGrid Libraries) turned on. You can set the growth ratio low and it is much better than the old Advancing front mesher. It is also smart enough not to mess up your internal walls or other existing mesh.
Simon
Old   April 22, 2010, 02:51
Attesz's Avatar
Attesz
Thanks Simon, I've 12.1 now, I'lll try it!
Attesz
Old   October 15, 2011, 10:33
akj
anil
akj is on a distinguished road
hey m also dng d same kind of problem. can u plz guide me how to mesh the periodic section....
akj is offline   Reply With Quote
Old   October 15, 2011, 10:42
akj
anil
plz help me i wana do meshing of a compressor blade its a periodic section or we can say a fluid flow profile up to there i hav completed and nw i want to mesh it and i want to do a unstructured mesh as structured mesh takes more computational time so plz help me and tell me how to proceed if ur having any tutorials related to that and if u can send me i will be very thankful to u....my email id is anil.jazzya@gmail.com
looking forward for your response.....
Old   June 5, 2014, 08:54
Default Periodic
  #17
Nazim
shahid nadeem is on a distinguished road
Is it possible to make periodic in ANSYS Meshing and please tell me what is the exact need to make body periodic. how should i cut the body and how should i do the mesh and which tip you are talking about
thank You
shahid nadeem is offline   Reply With Quote
Old   June 6, 2014, 05:21
Javi
FJSJ is on a distinguished road
Hi Shahid,
take a look to this thread:
[ICEM] How define periodicity correctly in ICEM
It can be useful for you
FJSJ is offline   Reply With Quote
Old   February 27, 2020, 00:28
Aleksandr
metaliat93 is on a distinguished road
how to setup ICEM and fluent read my model site like priodical BC?
metaliat93 is offline   Reply With Quote
compressor, periodic
periodic boundaries Mary FLUENT 27 January 6, 2021 01:54
Periodic boundary conditions happy5jump FLUENT 6 May 3, 2017 00:36
Periodic boundary condition Arif FLUENT 3 March 9, 2017 01:18
Why can't I make the boundaries periodic? Alina FLUENT 5 April 12, 2012 14:06
Must periodic oscillation give periodic results? zonexo Main CFD Forum 6 May 13, 2007 15:36
