[Other] Turbogrid blade geometry
Like Tree2Likes
  • 1 Post By D.B
  • 1 Post By Ahmed Saeed Mansour
Old   March 13, 2010, 16:46
Default Turbogrid blade geometry
Pepe
snatch is on a distinguished road
Hi there,
I´m creating the geometry of a one-stage compressor. I have the geometry in .curve files. The shroud and the hub are created without any problem. However, when I create the blade profile it gives me the following error:
ERROR get parametric curve: The start and end parametric value are the same.
I have checked the tutorials and the .curve files of these, but I have not found any difference with respect to my blade_profile.curve file.
Thanks
snatch is offline   Reply With Quote
Old   January 27, 2011, 08:55
Default Same problem here...
Steven Diehl
stevendiehl is on a distinguished road
I am having a similar problem with turbogrid. Did you ever solve the problem, or get an idea about what was going on at least?
Thanks,
Steven
stevendiehl is offline   Reply With Quote
Old   June 21, 2011, 11:36
MrStuebb is on a distinguished road
I have the same problem. Did anybody of you solve the problem?
Thanks
MrStuebb is offline   Reply With Quote
Old   November 23, 2011, 22:15
Default Start and end parameteric value error
balaji_hrrn's Avatar
Fluidic Heat
balaji_hrrn is on a distinguished road
This is mainly due to wrong geometry error.. either, the blade is protruding out of the hub and shroud, or something related to your co-ordinate definition..
balaji_hrrn is offline   Reply With Quote
Old   November 23, 2011, 22:34
D.B
DB
D.B is on a distinguished road
I had used Turbogrid a long time back so I am not sure about the answer, but here it is
While giving the balde profile each spanwise location airfoil co-ordinates should be separated by a heading ' profile #' . Also each airfoil 'profile' should have its co-ordinates ( i.e. either of x/y/z ) in either ascending or descending order and the order shoul be same for all the profiles.
ama294 likes this.
-D.B
D.B is offline   Reply With Quote
Old   November 28, 2011, 10:07
Max Efficiency is on a distinguished road
Maybe there is one point twice in your blade-file. If that is the case you have to delete one of that two identical points. Each point must be unique in the curve-file for TurboGrid.
By point I mean one point described with x,y,z-coordinates for example.
Max Efficiency is offline   Reply With Quote
Old   May 9, 2012, 09:16
Default Solution to Start and End Parameters ERROR
Fluidic Heat
I have found this fix by accident. It happens, when TurboGrid is not able to create the Shroud Tip, due to one or the other method specified by you (Variable Normal Distance, Constant Span, etc.,.). Make sure you have a Tip profile defined in your profile.curve file, and select the corresponding Profile number. This error will be fixed. I have tried this, and this works 98 out of 100 cases.
Old   November 6, 2013, 06:37
Arslan
ArslanOZCAN is on a distinguished road
I tried the this but it didn't solve the problem ! By the way there is an inconsistent sizing. Although i work in milimeters, in machine data page i can't choose mm because it gives error. So i choose cm. Does it related with the above mentioned problem ?
ArslanOZCAN is offline   Reply With Quote
Old   September 25, 2015, 05:58
Maxim
-Maxim- is on a distinguished road
I just came across this error, too. I replaced a blade with a slightly bigger one in DesignModeler. Due to the different size, the lines of the blade in the 'ExportPoints' feature intersected with the 'Outlet' line. I had to shift the the 'Outlet' line a few millimeters downstream to fix the error.
-Maxim- is offline   Reply With Quote
Old   August 18, 2016, 10:57
Have a nice time!
Ahmed Saeed Mansour is on a distinguished road
YES!!!! IT WORKS THANKS FOR THE RECOMMENDATION!!!!
-Maxim- likes this.
Ahmed Saeed Mansour is offline   Reply With Quote
[TurboGrid] GE rotor B geometry for Ansys turbogrid sonny ANSYS Meshing & Geometry 6 August 29, 2014 20:01
[ICEM] importing a geometry from Turbogrid to ICEM c120613 ANSYS Meshing & Geometry 1 May 14, 2013 23:59
Looking for Pak-B LPT blade geometry coordinates yossarian88 Main CFD Forum 1 August 16, 2011 11:40
Wind Turbine Blade Geometry SeanieB Main CFD Forum 0 November 27, 2009 10:18
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
