Connections of edges and faces between bodies (Workbench v12) |
julien char
Rep Power: 16 ![]() |
Hello everyone,
I am working on the seperation flow arround a prolate spheroid. Goal of my project: - improve the meshing with a quad method to obtain good aspect ratio and good skewness. - target the separation flow very close to the prolate spheroid. Method: - Split the global spherical volume in some quadrilateral sector as shown in the pictures. - Inflation meshing to see the boundary layer arround the body. Main problem : How can I do to share every edges and faces between bodies? Right now the gap between them generate a different meshing both side of the interface. The following pictures illustrate this project and this problem. Thanks for your help. |
Simon Pereira
Rep Power: 47 ![]() ![]() |
You need to combine the parts into a multibody part so that you will get conformal mesh...
You can do this in the geometry branch of the model tree. Simon |
julien char
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
ICEM:copy-rotate -> single edges, uncovered faces? | Zulu | CFX | 2 | January 6, 2009 13:51 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
