[ICEM] Weighted Mesh / Gradually Coarsening Mesh
Like Tree1Likes
  • 1 Post By PSYMN
Old   June 15, 2010, 22:42
Default Weighted Mesh / Gradually Coarsening Mesh
Pawan Kumar
pawan1989 is on a distinguished road
This is really annoying me. I am used to Gambit for a few years and now trying out ICEMCFD. Am I missing something trivial? It was really easy in Gambit.
Here's a simple example and I don't know how to do this: I have a plain 2D surface, lets say a rectangle and I want the surface mesh to be more dense by the "inlet" and less dense as it gets to "outlet". That's it, simple one-way gradient. I want to be able to somehow manage that density and how much I want to distribute the mesh. So the edge nodes would look something like this I suppose:
ooo-o-o-o-o--o--o---o---o-----o-----o---------o----------o---------------o
Any help would be greatly appreciated.
pawan1989 is offline   Reply With Quote
Old   June 16, 2010, 11:12
Default Lots of Power for Edge distribution control...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Are you using ICEM CFD Hexa blocking? Go to Premesh Params => Edge Params... You will find excellent control with a variety of Meshing Laws, Spacing 1, spacing2, ratios, max space, etc.
If this isn't enough, you can choose the Mesh law => From Graphs. This lets you create your own distribution using a graph. Just click and drag to add points. There are also functions you could start with and you could use linear or splines between your control points. This example is somewhat silly, but I wanted to show the idea... The graph in the top half controls the bunching distribution...
There is also a Mesh law => Onscreen that lets you maniputlate the distribution directly on the edge...
Once you have the distribution you want, you can copy it to parallel or visible, etc. There really is a lot of power there.
Do display your bunching, right click on "edges" in the model tree and display the "bunching". The sice with the base of the arrow is side 1, the other side is side 2.
If you are paving your mesh, then you can find similar (but less flexible) functionality under the Mesh (tab) => Curve Mesh Setup. Scroll down to advanced bunching. To see the curve distribution, you can right click on curves in the model tree to display "curve node spacing"
PSYMN is offline   Reply With Quote
Old   June 16, 2010, 11:13
Default Try some tutorials
PSYMN's Avatar
Simon Pereira
And yes, this should be covered by most of the Hexa tutorials. Try out a few since there are lots of other key bits of info that will help you out also.
Simon
Old   June 16, 2010, 13:18
Pawan Kumar
Thanks! I shall be sure to try them out and let you know how it goes. I appreciate your time and effort.
Old   February 8, 2012, 10:33
Leepox is on a distinguished road
I have gone through the hexa tutorials but I haven't found one which discusses how the gradients become denser approaching both ends of a mesh. Can anyone suggest which mesh law would be best to implement?
ooo-o-o-o-o--o--o---o---o-----o-----o---------o--------o-----o---o--o-o-ooo
Sorry for hijacking the thread, but I thought this is very relevant. Thanks!
Leepox is offline   Reply With Quote
Old   February 8, 2012, 20:30
PSYMN's Avatar
Simon Pereira
Bi-geometric or bi-exponential... Or chose the graphs option and create your own meshing law...
Leepox likes this.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
Coarsening mesh in Fluent Ibuki FLUENT 6 April 8, 2016 04:22
cooper mesh coarsening with tri meshed source Ralf Schmidt FLUENT 2 January 31, 2008 08:50
Mesh for 3 dim Geometry Phil FLUENT 9 July 12, 2000 04:39
Mesh Mignard FLUENT 2 March 22, 2000 05:12
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
