[GAMBIT] Volume meshing error - "edge intersects face"
Old   September 13, 2010, 12:12
Default Volume meshing error - "edge intersects face"
Laura
lucille is on a distinguished road
Hello
I am trying to mesh a complex volume using the Tet/Hybrid; Hexcore (TGrid) scheme and persistently get an error which states "edge intersects face". Have tried varying my edge, face and BL meshes but continue to get this error. Does this reflect an issue with my geometry?
Any assistance or insight is appreciated. Looking through past posts I see others have run into this issue but don't see where anyone has gotten through it.
Thank you
lucille is offline   Reply With Quote
Old   September 14, 2010, 03:23
-mAx-'s Avatar
Maxime Perelli
First try to mesh your volume without BL.
Post also a picture of your geometry.
Old   September 15, 2010, 09:09
Default It worked!
Laura
I took out the BL and it worked fine - not sure what the issue was, but I was able to mesh successfully without BL but with more buffer and peel layers. Thank you.
Old   September 15, 2010, 09:20
-mAx-'s Avatar
Maxime Perelli
Then you know where the problem is.
It is a mesh problem, and not a geometry-one.
So you can re-create your BL, and you can preview the boundary layer:
Mesh/Boundary Layer/View 3D Boundary Layer
volume meshing
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
