[ICEM] Meshing Parameters
Old   October 13, 2010, 14:00
Default Meshing Parameters
fnes is on a distinguished road
it’s my first time using ICEM. Do you solve a problem, you have the next.
But now a can’t find a solution.
The picture shows my problem. Does anyone knows why the lower middle knots connect to the upper right edge and not to the upper middle?
Thanks.
fnes is offline   Reply With Quote
Old   October 19, 2010, 13:42
Default Group Curves?
PSYMN's Avatar
Simon Pereira
Edges are associated with curves... Make sure that the edge associates to all the curves along the way. Perhaps there is some curve segment that you have not associated it to, so the nodes are projecting only to the curves you did select...
From that picture, it is hard to know exactly what is wrong...
Zoom in and take a better pic with edge bunching, curves, etc. But not surfaces or other things that get in the way.
Old   October 29, 2010, 05:43
Default Unsymmetric Wing
Thanks for answer.
Dividing the block between the wings, solves the problem.
Now the wings are unsymmetric. Pic 1 shows the body. Everything is symmetrical. But at the edge of the O-Grid the wing is unsymmetric (pic 2).
I followed the tutorial "Wing Body" because my solid is similiar but the result is not satisfying.
Has someone an idea?
Thanks.
Bug in Meshing Parameters menu Spacing1 (1e+10) Karna ANSYS Meshing & Geometry 1 October 12, 2009 14:38
Importing meshing parameters in CFX-Mesh Antti Kultanen CFX 0 June 16, 2008 11:39
difference between Meshing Parameters Mihail CFX 1 April 29, 2008 03:44
parameters in proamm volume meshing Ghali Siemens 2 July 7, 2006 06:57
Meshing with parameters Renaud FLUENT 0 May 30, 2006 09:02
