February 13, 2011, 14:48 |
rotation in gambit
Morteza
hi
i have modeled a symmetric 2d impingement jet in gambit... but i assign the y-axis as symmetric line.. when i run it in fluent the y-plus has a illegical value of 150 somebody told me that when you design a symmetric model in gambit, symmetry line must be x-axis. is this true? if yes ,is there anywayo to rotate my model in gambit for changing the symmetry line to x-axis.. rotation around a axis or any arbitrary line.. thanks |
February 14, 2011, 01:57 |
Maxime Perelli
Rep Power: 41 |
move one surface: select rotate and give the right rotation's vector (with angle)
Enable connected geometry option.(if your geometry is connected, all you domain will rotate. If not, then you need to fix the connectivity)
In memory of my friend Hervé: CFD engineer & freerider |
Gambit help: Cube inside cube | Jack Martinez | FLUENT | 13 | August 11, 2010 06:29 |
Gambit 2.3.16, Xming or Exceed...HELP! | bambam3417 | FLUENT | 10 | May 7, 2010 12:39 |
Gambit -dev X11 doesn't work | Ervin Amet | FLUENT | 0 | October 28, 2007 08:33 |
Axis of rotation for centrifugal compressor | Mattia | FLUENT | 4 | October 22, 2007 11:05 |
Gambit Rotation | Ed | FLUENT | 2 | December 15, 2006 09:16 |
