[GAMBIT] Periodic BC
Old   May 31, 2011, 03:30
Default Periodic BC
truffaldino's Avatar
truffaldino is on a distinguished road
I have a problem which might be easily fixed with your help. I have created a 3d mesh for an airfoil, which is basically 2d with translation by .2m along z-axis, i.e. it has two identical x-y meshes one at z=0 and another at z=.2 that are periodically linked along z-direction (see figure). I have set boundary types as necessary in Gambit with no errors, but when I check the mesh in fluent I get the following message:
Periodic zone 3: x-translation: min (m) = -1.112668e+000, max (m) = 1.200599e+000
y-translation: min (m) = -1.276517e+000, max (m) = 1.132584e+000
z-translation: min (m) = 2.000000e-001, max (m) = 2.000000e-001
Done.
WARNING: Mesh check failed.
So there appear some strange translations in x and y-directions, which should be zero. When I ignore this warning and start solution in fluent I get meaningless result.
I will be grateful if someone could help me. I feel that it is something elementary.
Truffaldino
truffaldino is offline   Reply With Quote
Old   May 31, 2011, 07:17
-mAx-'s Avatar
Maxime Perelli
In gambit, define your 2 periodic surfaces as wall.
Re-export, and load your mesh in Fluent.
If the check Mesh is succesfull, then you problem lies on periodic surfaces
Old   May 31, 2011, 18:50
Thanks mAx,
I did as you said and check is successfull with walls. Now I am trying to find what is wrong on periodic surfaces, but everything seems to be fine.
During the check wth periodic BC fluent also gives the following message
Reading "C:\Fluent12\wing.msh"...
194095 nodes.
15289 mixed shadow faces, zone 2.
15289 mixed periodic faces, zone 3.
15289 shadow face pairs.
17178 triangular shadow faces, zone 4.
17178 triangular periodic faces, zone 5.
17178 shadow face pairs.
2350 quadrilateral wall faces, zone 6.
1110 quadrilateral velocity-inlet faces, zone 7.
250 quadrilateral pressure-outlet faces, zone 8.
789613 mixed interior faces, zone 10.
324670 mixed cells, zone 1.
which shows some "shadow faces". What are those?
Truffaldino
Old   June 1, 2011, 00:50
-mAx-'s Avatar
Maxime Perelli
you can select them and display them in Fluent.
You will see where they are
Old   June 5, 2011, 06:39
Thanks mAx,
Unfortunately fluent does not show those side faces.
I have decided to try to try with much simpler mesh, simple periodic cube: Check mesh failed in fluent even for this primitive example. There is no single error or warning in gambit, but in fluent it shows non-existent translations in x,y-directions.
I will be grateful if someone could point me on my error.
Below I write down simple journal code for this test cube meshing (see image attached):
reset
$version="FLUENT 5/6"
$mesh_output_file="C:\\Fluent12\\periodic.msh"
$L=1
$H=1
$z=1
$q_bl=1.2
$n_bl=5
$n=10
$n1=5
$nh=11
$nz=3
$dh_bl=.01
solver select $version
/create side (x,y)-face "P"
vertex create "A" coordinates 0 0 0
vertex create "B" coordinates $L 0 0
vertex create "A1" coordinates 0 $H 0
vertex create "B1" coordinates $L $H 0
edge create "A_A1" straight "A" "A1"
edge create "B_B1" straight "B" "B1"
edge create "A_B" straight "A" "B"
edge create "A1_B1" straight "A1" "B1"
face create "P" wireframe "A_A1" "B_B1" "A_B" "A1_B1"
/--- Meshing this side (future periodic) face
edge mesh "A_B" successive ratio1 1 intervals $n
edge mesh "A1_B1" successive ratio1 1 intervals $n1
blayer create "bl" first $dh_bl growth $q_bl rows $n_bl wedge uniform
blayer attach "bl" face "P" edge "A_B"
edge mesh "A_A1" "B_B1" successive ratio1 1 intervals $nh
face mesh "P" triangle
/--- Creating volume by translating side (x,y)-face in z-directiobn
volume create "V" translate "P" vector 0 0 $z
/--- Wall (bottom) face
face modify "face.2" label "W"
/--- Inlet faces
face modify "face.3" label "Il"
face modify "face.5" label "It"
/--- Outlet face
face modify "face.4" label "O"
/-- Second periodic face
face modify "face.6" label "Pz"
/edges and vertex for periodic linking
vertex modify "vertex.5" label "Az"
edge modify "edge.5" label "A Az"
edge modify "edge.9" label "Az_Bz"
edge modify "edge.10" label "Az_A1z"
/--- Linking periodic faces
face link "P" "Pz" edges "A_A1" "Az_Bz" vertices "A" "Az" reverse periodic
/--- Meshing one edge in z-direction
edge mesh "A Az" successive ratio1 1 intervals $nz
/--- Creating groups and BC
group create "Periodic" face "P" "Pz"
group create "Wall" face "W"
group create "Inlet" face "Il" "It"
group create "Outlet" face "O"
physics create "periodic" btype "PERIODIC" group "Periodic"
physics create "wall" btype "WALL" group "Wall"
physics create "inlet" btype "VELOCITY_INLET" group "Inlet"
physics create "outlet" btype "PRESSURE_OUTLET" group "Outlet"
/--- Final meshing
volume mesh "V" cooper
/--- Saving mesh into file
export uns $mesh_output_file
Periodic boundary condition Arif FLUENT 3 March 9, 2017 01:18
Why can't I make the boundaries periodic? Alina FLUENT 5 April 12, 2012 14:06
problem about periodic boundary condition in Fluent winnawinna FLUENT 0 December 28, 2010 23:32
[ICEM] Specifying Periodic Vertices Causes Mesh Overlap Josh ANSYS Meshing & Geometry 10 July 8, 2010 02:39
Activate Periodic Conditions IvanCFD FLUENT 3 May 13, 2010 07:02
