[ICEM] o'ring not taken into account in the mesh in 3D error |
June 9, 2011, 19:09 |
eleo lecoeur
Rep Power: 14 |
Hello, I have a problem using the o'ring in 3D with ANSYS ICEM.
It is working ok in 2D (a circle): The o'ring changes the shape of the mesh. In 3D, once I have meshed a cylinder, I then create the o'ring, but the o'ring is not merged in the mesh. Can you indicate me why? Thank you in advance. Last edited by eleo; June 13, 2011 at 14:09. |
June 9, 2011, 23:28 |
jeevan kumar
Rep Power: 17 |
It will be difficult to know what is the problem in the mesh without images. if you can upload some images or the tetin and blockinf files then it will be easy to understand your problem.
Regards jeevan |
June 13, 2011, 14:07 |
Pb: mesh does not take into account the o-ring in 3D-Ansys ICEM mesh
eleo lecoeur
Rep Power: 14 |
It is working ok in 2D (a circle): The o'ring changes the shape of the mesh. In 3D, once I have meshed a cylinder, I then create the o'ring, but the o'ring is not merged in the mesh. Can you indicate me why? Thank you in advance. Please find attached the files for respectively the 2D case and the 3D case : cercl.zip cyl1.zip cercl1.zip cyl.zip |
June 13, 2011, 14:57 |
#4 | |
ousegui
Rep Power: 15 |
try with this block file
June 13, 2011, 15:37 |
Blocking
eleo lecoeur
Rep Power: 14 |
Thank you Ousegui, the new blocking is working ok. Could you indicate me why my blocking was wrong ? Thanks.
Eleo |
June 13, 2011, 15:48 |
ousegui
Rep Power: 15 |
I think the problem that you create three block (for bottom top and lateral surfaces) and after you made the o grid.
The correct way is to create one block for the all geometrie assciate the edges surounding the discs to the cercles, and creat o grid by selecting the block and the faces of discs and it will work good luck |
June 14, 2011, 16:10 |
Problem with the blocking
eleo lecoeur
Rep Power: 14 |
Hello
1) From the geometry file cyl1 attached previously, I click on blocking>1st icon Part: live Create block Initialize blocks 3D Bounding Box – Project vertice is ticked –Apply One box is created- 2) Then, I click on Blockink and 2nd icon Split Block + 2nd icon Select block I click on the 1st icon –go on the geometry and type "v" on the keyboard- the block appears Then select face and 1st icon- I select the inlet and the outlet- And Apply- I don’t manage to get the same blocking than you ie which remains planar at both side when you look at it on a side view. Do you use my geometry to create your blocking ? Do I have to change anything in the geometry before creating the block or is there anything wrong with the way of moving the vertices ...? Thanks for your help. Eleo. |
June 14, 2011, 19:11 |
#8 | |
ousegui
Rep Power: 15 |
honestly I don't know what's wrong with your approach, for me I use your geo file and I did the block and O grid, it's a basic case, just do some cases in tutorials and you will achieve your example easily
Regards Quote:
June 14, 2011, 19:46 |
Ansys ICEM Version
#9 |
eleo lecoeur
Rep Power: 14 |
Could you please let me know which version you are using ? I am using 11.0. Do you think my software could be corrupted. Thanks.
mesh icem o'ring error |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 17:43 |
OpenFOAM install on Ubuntu Natty 11.04 | bkubicek | OpenFOAM | 13 | May 26, 2011 05:48 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
[Netgen] Installation of Netgen in SuSE Linux 92 | edvardsenpriv | OpenFOAM Meshing & Mesh Conversion | 23 | January 16, 2009 06:12 |
