Mesh file format: basic information about materials |
June 20, 2011, 08:55 |
Rep Power: 15 |
I'm meshing geometries in ICEM CFD and then export these meshes in fensap format to be used later. The problem is that there is no information about materials in this mesh format. I need just the basic info "material - mesh element", for example: Material #1: elements 1, 2, 6, 7, 8, 11, 12 Material #2: elements 3, 4, 5, 9, 10 Are there any mesh formats (ascii) that include this information? Thanks! |
June 24, 2011, 12:55 |
Simon Pereira
Rep Power: 47 |
Sure... These properties are not in the uns file, but they can be included in the output files...
First change your settings => Product so you can have FEA options. This will add a properties tab (along with loads and constraints tabs). Under Properties, you can add material properties to the volume elements. Then output in an FEA format that supports material information... Like ANSYS or Nastran or LS-DYNA or ABAQUS...
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
June 27, 2011, 03:28 |
Rep Power: 15 |
Thanks! I'll try to play with all these formats.
March 24, 2012, 11:21 |
Mesh for Fensap
#4 | |
amin
Rep Power: 14 |
Hi, I also have problem like you about material in mesh file for importing to FENSAP_ICE. I want to know, could u solve your problem?? if yes, I become happy to guide me, Tnx a lot. Best Regards. |
icem, material, mesh format |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
OpenFOAM Install Script | ljsh | OpenFOAM Installation | 82 | October 12, 2009 11:47 |
Gambit mesh to PATRAN neutral file format | Satya | FLUENT | 0 | May 18, 2004 16:57 |
