August 2, 2011, 12:26 |
Mutiple Edge problem
William Shaw
Rep Power: 16 |
dear all,
I tried to make a room which adjacent to the outside environment(use a Big box instead) to simulate a HVAC problem, but somehow the blue lines in the prcture show those edges have 3 surfaces meeting and when i tried to mesh it using tetra mesh the mutiple edge problem came. how could I solve this problem? thanks! |
August 3, 2011, 06:45 |
Mohankumar.G
Rep Power: 16 |
In your problem I think you have created 2 body points, so the edge that meets the two zones have three faces and it is shown in blue color.
In your meshing definitely there will be multiple edges, actually multiple edges are not an error unless it occurs in unnecessary places. Regards, Mohan.G |
August 3, 2011, 06:50 |
#3 | |
William Shaw
Rep Power: 16 |
Running diagnostics for Multiple edges in subset "all" 228 problems were found for Multiple edges. Is this ok? |
August 3, 2011, 07:37 |
Mohankumar.G
Rep Power: 16 |
For your case the multiple edges will be there and it is not a problem.
August 3, 2011, 11:38 |
possible problems.
Simon Pereira
Rep Power: 47 |
Correct. For most solvers, multiple edges (where intended) are not a problem. But for some solvers, or when you don't expect them, they can be a problem. This is why they are listed in the checks under the "possible problems" column.
I would add to Mohankumarg12's reputation, but the button says I have done it too much already.
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
mesh, mutiple edge |
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 | maverick | OpenFOAM Meshing & Mesh Conversion | 2 | June 18, 2011 04:36 |
[ICEM] [Student] Problem: Nodes Merging | FALCON_SR71 | ANSYS Meshing & Geometry | 8 | March 21, 2010 05:47 |
Through-Flow solver, Leading-Trailing edge problem | Menander | Main CFD Forum | 0 | May 14, 2008 18:14 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
mesh control problem | TUM | CFX | 4 | July 27, 2001 16:17 |
