ICEM CFD- Error: prism terminated prematurely
Like Tree3Likes
  • 1 Post By BrolY
  • 2 Post By PSYMN
Old   September 19, 2011, 13:47
Default ICEM CFD- Error: prism terminated prematurely
user0314 is on a distinguished road
I am trying to mesh a 3D geometry in ICEM and create prism layers. I am using tetra unstructured mesh.
I first generate the mesh, and run mesh check. There are no errors. Next I run prism and get the following error:
prism: swap. C:616: base_vertex* check_collapse(base_vertex*,base_vertex*,unstruc_m esh*,check_collapse_opts*,merge_data*): Assertion e1->ptwin()->ptwin() = e1' failed.
Application is finished
Error: prism terminated prematurely.
Does anybody have an idea what this error could mean?
Thanks!
user0314 is offline   Reply With Quote
Old   September 20, 2011, 05:43
AB
BrolY will become famous soon enough
We need more info such as pictures of the geometry or how you proceed to specify your prism parameters !
BrolY is offline   Reply With Quote
Old   September 20, 2011, 09:49
Default more information and reply
I am simulating is a 3D pi slice of a disk. There is a pi-shaped column of fluid above the pi slice. The disk is filled with a porous material and there is a suction cavity below the porous material.
I specify the prism parameters as:
initial height: 0.001
height ratio: 1.1
number of prism layers: 20
There are prism layers along all of the walls, as well as on the surface of the disk.
Old   September 20, 2011, 09:53
Default Picture of geometry
Attached is a picture of geometry.
Old   September 20, 2011, 10:03
Default More prism info
min prism quality: 0.00001
ortho weight: 0.5
fillet ratio: 0.35
max prism angle: 176
Old   September 20, 2011, 10:05
AB
Did you try to create only 1 prism layer to see what's going on ?
And post the picture of the result, it may help
majid fahim likes this.
Old   September 20, 2011, 10:16
Default pic of result
Here is a zoomed in picture of the result. It looks like it created 1 layer correctly. But creating multiple layers is causing a problem.
If you need a different view, just let me know!
Old   September 20, 2011, 10:23
Default splitting prism layer
I tried splitting the prism layer. Seems to work, but how come I can't create multiple layers at one time? I would like to be able to do that.
Is there advantage/disadvantage to either method?
Old   September 20, 2011, 10:55
AB
I don't know why you can't create multiple layers at one time. Maybe ICEM acn't handle so many layers with your geometry. Maybe at some point, there are intersections which can't be fixed.
Make a research on this forum about that topic, you will find a lot of answers to your questions
Old   September 20, 2011, 13:21
Default It just won't fit...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
In the image you showed, there is a thinner lower region that is a green/teal color... This region is only 3 elements deep. If you try to grow too many layers, the corner of the prisms will come up at a 45 degree angle and will eventually get to close to the interface between the green/teal and the blue/cyan regions... Since that is a change in material, it represents a hard wall and prism will get stuck or break down...
You are not stuck with 1 layer though... Try 3 or 5 and see how it goes. Check and corner and see how tight things are getting to decide if you can try with a greater number of layers...
Some times the number of layers you think you want just won't fit...
You could even try different numbers of layers in different regions based on what the geometry can accommodate...
Younis saleh and lukasf like this.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
[ICEM] Icem CFD on Linux mechanicaldesign ANSYS Meshing & Geometry 7 March 11, 2021 19:44
Need help icem cfd kakhtar ANSYS Meshing & Geometry 25 January 31, 2017 01:09
Transport mesh from ICEM CFD, to Fluent, to Sysnoise Wieland FLUENT 2 April 15, 2012 06:28
Importing Solidworks part into ICEM CFD MetalSupremacist FLUENT 0 October 8, 2010 17:46
Importing geometry from Pro E to ICEM CFD V5.1 sac CFX 2 January 16, 2006 08:38
