[ANSYS Meshing] ICEM-CFD- Geometric cleanup
Old   November 3, 2011, 02:13
Default ICEM-CFD- Geometric cleanup
Mohankumar.G
Mohankumarg12 is on a distinguished road
Sorry guys it is ICEM-CFD thread I overseen the prefix pull down menu.
I am using a 16 GB workstation for my CFD meshing and simulation.
When I am doing geometric cleanup in ICEM-CFD for a file size of 60MB the system is very slow.
For example if I want to create a surface with 4 curves it takes me nearly 15 to 18 sec. My geometric cleanup is more in this model but at the same time if I am doing it in Hypermesh it is very much faster.
Is there any way to improve the speed of working in ICEM-CFD?
Thanks and regards,
Mohan.G
Mohankumarg12 is offline   Reply With Quote
Old   November 3, 2011, 02:56
Michal
Twix is on a distinguished road
Try to increase number of the processors, it improves speed of mesh generation and smoothing. I’m not sure if it works for geometry so you have to try. To do so, go to Settings -> General -> Number of Processors.
Regards
Twix is offline   Reply With Quote
Old   November 4, 2011, 20:30
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
No, the geometry tools are not parallelized... But the "tri tolerance" is important. If you make it much smaller, it will render much finer, but take more memory and CPU.
I usually make the tri-tolerance finer when I am doing a number of trim or intersection operations, but then reduce it for the rest of the time.
The past couple releases included a number of improvements to the display and selection speed, so getting a newer version (13.0 or 14.0) will help.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   November 7, 2011, 07:54
Mohankumar.G
Hi Thanks for the replies.
Where to find the option, as I tried to find it but I am unsuccessful.
Thanks,
Old   November 7, 2011, 08:56
PSYMN's Avatar
Simon Pereira
If looking for something like this, you can always "search" the help. Just type in what you want and hit "search".
In this case, it is a setting and can be found under "settings => Model". Triangulation tolerance should probably be about 0.001. If you see it set to 0.000001 or something like that, it will explain your whole problem.
Best regards,
Simon
[ICEM] Icem CFD on Linux mechanicaldesign ANSYS Meshing & Geometry 7 March 11, 2021 19:44
Need help icem cfd kakhtar ANSYS Meshing & Geometry 25 January 31, 2017 01:09
CFD Design...The CFD Future John C. Chien Main CFD Forum 20 November 19, 2015 23:40
Transport mesh from ICEM CFD, to Fluent, to Sysnoise Wieland FLUENT 2 April 15, 2012 06:28
[ICEM] Export unstructured periodic mesh from ICEM CFD to Fluent ivanddd ANSYS Meshing & Geometry 1 February 3, 2011 00:51
