[ICEM] Meshing an airfoil using C grid, some curves have no elements
Old   November 16, 2011, 16:46
Default Meshing an airfoil using C grid, some curves have no elements
Tom
tmartin is on a distinguished road
Hi there, new to this forum and to CFD more generally.
I'm trying to mesh a NACA0012 according to the instructions given in http://www.youtube.com/watch?v=EknKVAJGEJ8 (though with a larger far-field) in order to export to FLUENT for solving.
Now, the above video creates the far field as one part and associates three of the edges to curves at once. I really don't understand how this can be made to work with FLUENT, as the only way I'd got FLUENT to work in the past is using separate parts/families for inlet, outlet, top and bottom as the video annotation suggests. Anyway, when I import into FLUENT as in the video, I find that I don't have any zones to create, for example inlet (velocity-inlet) BCs - the inlet simply does not appear in the list, only OUTLET and BOTTOM.
If I right click the INLET or TOP in ICEM, I'm told that there are no elements associated with either of them. OUTLET and BOTTOM are okay though. I ungrouped the curve, and associated the edges to the curves individually and renamed the parts INLET, OUTLET, TOP and BOTTOM and re-built the mesh. Unfortunately, when I export the mesh into FLUENT, the same thing happens.
I've got FLUENT working with an H grid mesh before so I get the feeling it's to do with the C grid somehow... I'm basically just really confused. Would very much appreciate any help and I will do my best to add more detail if I can.
tmartin is offline   Reply With Quote
Old   November 16, 2011, 18:42
raj
raj.cfd is on a distinguished road
1. You can import NACA0012 body co-ordinates in any of the CFD pre-processing software.
2. The farfield as a rule of thumb is 15-20 times chord length . create one.
3. You can generate C-grid, O-grid or H-grid or mixture of them and / or structured or unstructured.
4. Divide airfoil into different segments, segment 1 - leading edge, seg-2, from leading edge to suction side just before the trainling edge and similarly at the pressure side as well. connect this to the far feild boundary.
5. C-grid at leading edge, suction and pr. side and H-grid at the trailing edge can be generated.
6. Make sure to have a fine mesh gradient at the airfoil boundaries , since you will solve one equation model to capture very fine viscous effects at the boundaries.
raj.cfd is offline   Reply With Quote
Old   November 16, 2011, 18:45
Tom
Thanks Raj. I have a mesh generated already, far field is about 20x the chord, etc etc. The problem is that when I take export to FLUENT I can't add boundary conditions to the inlet, it doesn't appear as a zone under the boundary conditions tab. ICEM says there are no elements associated with the inlet for some reason, even though it really does look like it.
The only difference between what I've done already and what you suggested is the separate curves for pressure and suction sides, could this have an effect?
Old   November 16, 2011, 18:58
raj
Probably before taking it to fluent, you need to have different named selections like inlet, outlet, farfield, pr. side, suc. side etc etc in your pre-processing software and also depends if you are meshing it as a single body mesh or multibody mesh..
Airfoil Meshing Scheme in Gambit J. Weiler FLUENT 6 October 2, 2011 15:41
[Other] Ansys meshing airfoil and / or compressor blades baw192 ANSYS Meshing & Geometry 8 September 23, 2011 00:43
Basic steps meshing an airfoil [ICEM] peterputer111 ANSYS Meshing & Geometry 4 April 19, 2010 12:08
Meshing An airfoil with a simple plain flap S. Kalam FLUENT 7 January 30, 2005 20:22
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
