[ANSYS Meshing] Problems with Gambit + Convert to Ansys Meshing
Old   November 22, 2011, 07:47
Default Problems with Gambit + Convert to Ansys Meshing
Vincent Meertens
vmeertens is on a distinguished road
Send a message via MSN to vmeertens
Hi all,
I have following problem with Gambit since this weekend:
Locating Exceed installation ...
Launching Exceed 13 ...
Starting C:\Fluent.Inc\gambit2.4.6\ntx86\gambit.exe -device open -id default_id5596 -new ...
FATAL ERROR: Could not obtain valid license authorization.
Total of 0.02 cpu second(s), 102400 maximum memory.
*** Cannot connect to license server
The server (lmgrd) has not been started yet, or
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Feature: gambit
Server name: VMEERTENS-PC
License path: C:\Fluent.Inc\license\ntx86\..\license.dat
FLEXlm error: -15,10. System Error: 10061 "WinSock: Connection refused"
For further information, refer to the FLEXlm End User Manual,
available at "www.macrovision.com".
Feature: gambit-addon
available at www.macrovision.com.
I don’t really know what happened, but it just stopped working overnight.
I’ve tried to change the ports in the license files, but I can’t get it running.
After re-installing gambit and the license server, I still had the same problem.
When I use the command lmutil lmstat -a in the command prompt I only get
c:\>lmutil lmstat –a
lmutil - Copyright (c) 1989-2006 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved. Flexible License Manager status on Thu 1/29/2009 12:52
It should be more like:
:\>lmutil lmstat -a
[Detecting lmgrd processes...]
License server status: 8224@my_lic_server <- Name of server
License file(s) on my_lic_server: C:\\license.dat: <- License file location on server
my_lic_server: license server UP (MASTER) v10.8 <- lmgrd version
Vendor daemon status (on my_lic_server): <- the daemons running
armlmd: UP v10.8 <- daemon version
Feature usage info: <- list of components and current users
Users of compiler: (Total of 1 license issued; Total of 0 licenses in use)
So I don’t know what the problem is.
But anyway, I have started to use workbench now.
I have read that the FE Modeler can be used for importing the .dbs file.
Does anyone have experience with this?
Sincerely,
Vincent
vmeertens is offline   Reply With Quote
Old   November 23, 2011, 02:28
Vincent Meertens
It seems that the license probleme is also linked to Fluent. None of the programs work.
But ansys workbench isn't affected.
Maybe a reinstall of fluent and gambit will fix the problems.
[GAMBIT] 3D boundary layer and meshing problem in GAMBIT 2.4.6 prashanthreddyh ANSYS Meshing & Geometry 1 December 20, 2011 00:35
[GAMBIT] Desperate student needs help meshing 3D GAMBIT model - please help! lau06165 ANSYS Meshing & Geometry 1 March 22, 2010 01:09
[GAMBIT] Meshing problems iHal ANSYS Meshing & Geometry 6 February 25, 2010 08:21
Gambit: too long meshing time! delsolman FLUENT 1 January 29, 2008 19:06
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 20, 2006 23:31
