[DesignModeler] simulating a moving body in a flowing field |
November 28, 2011, 11:32 |
Ro'ee Orland
Rep Power: 15 |
hello,
I'm trying to simulate a solid body flowing inside a pipe. how do i create the geometry in design modeler? I've tried using the freeze and subtract tools but in both cases the body does not move. many thanks for your help! |
December 2, 2011, 10:07 |
Rep Power: 16 |
What do you mean moving body? If you want to change its position you can use "body operation - translate", if you want to solve the flow field of a moving body, try CFX instead of DM.
December 2, 2011, 12:22 |
#3 | |
Ro'ee Orland
Rep Power: 15 |
I want to create a geometry in which the body will be able to move due to the flow field inside the pipe.. Thanks for the help! Link to image: http://i44.tinypic.com/5ys0ft.jpg |
December 13, 2011, 11:17 |
Kailash
Rep Power: 15 |
you need to have a seperate volume around the cylinder and specify it as a rigid body with translatory dof.... u should activate remeshing in the volume outside the rigid body...
Simulating How does body flows on fluids by Demonstrating Bernolies | dhasthagheer | OpenFOAM | 0 | April 16, 2011 21:27 |
about Cart3d and moving body | Tiger | Main CFD Forum | 0 | July 13, 2005 06:12 |
Moving Body Grid Question | Matt | Main CFD Forum | 5 | September 13, 2004 00:45 |
HELP: unsteady solving of Moving body in fluid | Quain Tchew | Main CFD Forum | 1 | May 21, 2003 23:21 |
Test for 3D moving body | Anvar Gilmanov | Main CFD Forum | 4 | May 1, 2002 11:34 |
