[GAMBIT] Is there a trick to aligning edge/vertices?
Old   December 19, 2011, 14:14
Default Is there a trick to aligning edge/vertices?
James
VU_Engineer is on a distinguished road
Imported a 3D ProE drawing but only need to run a 2D simulation
The vertices of my edges are not co-planner and all need to be in the XY-plane, but i am having real trouble trying to get them there...
Does anyone have any advice to bringing all the edges to the same plane?
VU_Engineer is offline   Reply With Quote
Old   December 20, 2011, 02:25
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Import your 3d geometry in Gambit.
Then create a XY-plane (big surface), and split your volume with the plane (plane dimensions have to be greater than your volume).
Once split is successfull, delete one of both volumes. (lower geometry enabled).
Delete the other volume, but with lower geometry disabled.
Delete now all the surfaces (lower geometry enabled), except the surface you want to use for your computation
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
=== Using multiple POSDAT.F - simple trick === Tommy Siemens 2 July 2, 2007 09:46
=== Using multiple POSDAT.F - simple trick === Murali Siemens 2 November 29, 2005 11:33
aligning mesh with a co ordinate axis in star cd rajesh Siemens 2 February 18, 2005 02:06
Mind Reader-What's the trick? Selina Tracy Main CFD Forum 5 April 24, 2003 12:18
