[ANSYS Meshing] Tetrahedral or Hexahedral
Like Tree1Likes
  • 1 Post By PSYMN
Old   December 21, 2011, 09:02
Default Tetrahedral or Hexahedral
Mina
Mina_Shahi is on a distinguished road
Dear Ansys users
I am going to mesh a 3D geometry, this geometry is rather simple one, and consisting 2 rectangulars part, 31 tubes with 1mm diameter are coneected to them acting as inlet boundaries, (see the attached file)
Now i am wondering that with these small tube which mesh method is better Tetrahedral or Hexahedral ? i am going to mesh it in Workbench and then do CFD analysis,
Mina_Shahi is offline   Reply With Quote
Old   December 21, 2011, 14:22
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
mix of both
Far is offline   Reply With Quote
Old   December 22, 2011, 05:52
Mina
Originally Posted by Far View Post
mix of both
Thank you for the answer, so Hex DOMINANT should be Ok in ansys workbecnh, true??
Old   December 22, 2011, 11:34
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
I agree with "Far", but don't recommend the Hexadominant method for CFD.
The Hexadominant method starts by paving quads at the walls and then marches inward with isotropic hexas which can crash somewhat badly in the middle. This is good for FEA structural analysis where most of the interesting stuff happens near the surface and uniform elements are sufficient to capture it all, but it is not good for CFD.
However, if you tried Multizone (or sweep) with an inflation layer, you could get a nice combination of swept hexas that would produce a good mesh for CFD.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   December 22, 2011, 11:42
Far
Sijal
What I wanted to say is "Always prefer the hexa mesh but when the quality cannot be maintained e.g. aspect ratio, skewness then it is better to switch to unstructured mesh".
Also in unimportant areas such as far-field use the unstructured mesh while using the structured mesh in boundary layer region, thereby inner mesh does not propagate in outer region.
Old   December 22, 2011, 16:36
Mina
Thanks for your suggestion, i tried Multizone or sweep but it gives errors even when i changed the grid size ... also Hexadominant is not good it gives a warrning. a warning message states that a low percentage of hex elements or poorly shaped hex elements may result. the only method which worked was Tetrahedrons. what do you think?
Old   December 22, 2011, 16:51
PSYMN's Avatar
Simon Pereira
Tetra is, by far, the easiest way to go and often a good way to start.
Your model looked simple enough to me that I thought MultiZone would have done nicely. Hexa is slightly better for quality and speed of convergence, but if the model is giving you trouble, go for Tetra/Prism...
One other thing you could try is "CutCel" hexa. It is as automatic as Tetra, but gives majority Hexa. It does use hanging nodes though so it really only works well with Fluent. Get 14.0 though, since it was improved a lot over 13.0 both in speed and robustness, especially when used with Prism.
Best regards,
Simon
Old   December 22, 2011, 16:58
Mina
Best regards,
Simon
Did you use ANSYS workbench for meshing? there are 6 methods to make a mesh, CFX mesh, MultiZone, Tetra, Hexa dominant, ...
There is no ""CutCel" hexa" on that? By the way how Tetra works from this point :numerical error or dissipation error ?
Thank you again
Regards
Old   December 23, 2011, 15:45
PSYMN's Avatar
Simon Pereira
Cutcel is not quite like all the others. It is a global method, so you don't set a method on a part or body, instead just left click on "mesh" in the model tree and then look down in the details panel. You will find a pull down that lets you turn on Cutcel.
I don't know what you are asking here
Old   December 20, 2012, 03:52
Question Warning in the Ansys Meshing
toda is on a distinguished road
Hello everybody,
I`m new in ANSYS, when I mesh some geometry in the Ansys Meshing, there is a warning: "Inflation created stairstep mesh at the some locations". What the meaning of this warning? If I use this mesh on Fluent simulation, is there any effect about this warning?
Thank you very much for the reply.
toda is offline   Reply With Quote
Old   December 20, 2012, 12:48
PSYMN's Avatar
Simon Pereira
Originally Posted by toda View Post
Hello everybody,
It just means that your prism layers are not all fully developed. So if you wanted 15 layers everywhere, but there wasn't room for 15 layers in some places, it will "step down" to 14 or less. Some solvers don't mind stair stepping at all (CFX), Fluent prefers full layers, but it really depends on where the stair stepping is.
Abdulrajak Buradi likes this.
Old   January 14, 2013, 23:55
Default VOF models on venturi scrubber simulation
  #12
Dear all.
My simulation is about venturi scrubber. A venturi scrubber is designed to effectively use the energy from the inlet gas stream to atomize the liquid being used to scrub the gas stream, so the gas stream will more clean. The end of the inlet water pipe there is some small nozzles. This venturi have 2 inlet and 2 outlet. Two inlet are inlet water and inlet gas. Because flow in venturi scrubber is turbulent, I make inflation in region near the venturi scrubber wall. The boundary conditions are inlet water=velocity inlet, inlet gas=velocity inlet, outlet1 and outlet2 = pressure outlet. In Fluent, I use models: Multiphase VOF, Energy Equation, and Viscous is k-epsilon. Multiphase have 2 eulerian phase, that is air and water liquid. The solution method is PISO. The absolute criteria of convergence is 1e-4 except energy (energy is 1e-6). After 7903 iteration, the simulation still not convergen. The simulation also have reversed flow in outlet1 and outlet2. Anyone can help me to solve this problem?? Is the multiphase VOF true for this problem?? Any help is highly appreciated. Thanks.
I`m sorry if the discussion is out of ansys meshing topic.
Best Regards
Toda
Old   January 14, 2013, 23:59
  #13
The more attachments about my simulation.
Best Regards
Toda
File Type: jpg Contours Total Temperature Magnitude.jpg (89.3 KB, 59 views)
Old   October 6, 2015, 03:57
Post Tetrahedral Mesh by workbench, element size definition
  #14
Soyol
soes is on a distinguished road
Hello all,
I have done a simulation in structured mesh by icem, and now I am switching to see the effect of unstructured mesh (tetrahedral) on my results.
I needed 1mm resolution for my structured mesh, but I don't know how to interpret this in the case of tetrahedral since it is not clear for me what the definition of element size in tetrahedral case in workbench meshing is.
I would really appreciate it if anyone can help me with the deifinition,
With best regards
soes is offline   Reply With Quote
Old   October 6, 2015, 10:44
Far
Sijal
Originally Posted by Soheil.esmaeilzadeh View Post
Hello all,
With best regards
make prism (inflation) to get similar mesh in normal direction
Old   October 6, 2015, 10:47
Soyol
Thank you so much for the reply, but my question is that what is exactly the concept of element size for unstructured grid, which edge does it refers to? or is it the third root of the cell volume? or maybe sth else?
Looking forward to hearing from you,
Soheil
Old   October 6, 2015, 10:50
Far
Sijal
For both cases do the mesh Independence test and you will know when you get equivalency. on element level it is very much difficult (impossible) to comment for some real cases.
May be you should go for some simpler cases to compare these things such as zero pressure gradient laminar flow over flat plate.
Tetrahedral vs. Hexahedral Meshing for CFD Andy Bartels Main CFD Forum 16 September 20, 2019 10:06
tetrahedral or hexahedral mesh? srr ANSYS Meshing & Geometry 4 September 23, 2010 12:56
Tetrahedral and hexahedral mesh based on FVM kuang Main CFD Forum 0 July 20, 2008 04:52
Hexahedral or Tetrahedral Maria Angelica Fidelity CFD 3 February 19, 2007 00:10
hexahedral vs. tetrahedral cells Christian Main CFD Forum 3 March 21, 2006 06:41
