[ANSYS Meshing] FLUID30 Declaration
Old   March 13, 2012, 10:10
Default FLUID30 Declaration
Rodrigo Vernini
5746085 is on a distinguished road
Is it the same to declare a geometry with e.g. FLUID30 using GUI from multiphysics or command line in mechanical?
With command line, i can just go to geometry and insert commands direct in the geometry?
I have the same assembly in solidworks and designmodeler, what's the best way to import it to multiphysics? Becuase when i make an IGS from design modeler, i can just see lines in Multiphysics, importing IGES.
I started yesterday this task of modeling a fluid system, and i'll need a lot of help with it, please, any information will save me a lot of time.
Thanks.
5746085 is offline   Reply With Quote
Old   March 13, 2012, 12:58
Rodrigo Vernini
Ok, i found out how to easily import the geometry in the multiphysics seen this:
http://www.youtube.com/watch?v=k3c_H_sAzZ8
compilation problem with "fvPatch::lookupPatchField" Ya_Squall2010 OpenFOAM Programming & Development 9 November 15, 2021 22:01
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
