March 16, 2012, 08:38 |
I am not sure getting your idea fully, but you can always reach the refinement tool at Edit Mesh/Adjust Mesh Density.
If you want many sets of meshes to be batch processed, maybe a script could help. |
March 19, 2012, 12:46 |
ICEM CFD Tetra mesh refinement tools...
Simon Pereira
Rep Power: 47 |
The ICEM CFD tetra refinement tool is a separate packet of code ( free, but not part of the regular distribution ) that can be added to ICEM CFD installation. It was basically made by one of our our support people in response to frequent requests for a batch tetra refinement tool. He worked with some customers to get a list of requirements and this is what we got...
BatchRefinement_Tools.jpg We will probably include it right in ICEM CFD at some future release (along with improvements driven by user feedback), but for now, I can send it to anyone who needs it. Since Far includes his email address, I just sent it to him directly. But it is so small, I guess I can just attach it here... Instructions can be found in the zip file... If you have feedback, please let us know.
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
April 19, 2012, 07:40 |
Refinement Tool: Not Working
Ali
Rep Power: 16 |
Hi:
I have try to use refinement tool as per procedure in the read me file. The icons and menu bar items did not display. No refinement menu opens. Kindly help me how to use it properly?
Best Regards Ali |
April 21, 2012, 00:15 |
Refinement Tool: Not Working - Reply
Ali
Rep Power: 16 |
Refinement tool is not working. I followed the instructions given in readme.txt. When I use command in cmd:
icemcfd -app refinement Icem opens with no icons and menu items but only icons of File menu. I can't do anything. Help me out, how to do so.. Its ICEM 14.
Best Regards Ali |
April 23, 2012, 03:02 |
Rep Power: 18 |
Put scripts into new directory "C:\Program Files\ANSYS Inc\v1*0\icemcfd\***\lib\ai_env\scripts\refinement \" (for example, recommended directory).
If you haven't path in the environment on your computer, write this: "C:\Program Files\ANSYS Inc\v1*0\icemcfd\***\bin\icemcfd.bat" -app refinement Refirement tools works fine. |
April 23, 2012, 12:41 |
Ali
Rep Power: 16 |
.prism_params file will be written when you make the initial course mesh using full version of ICEM.
The application works 50:50 (sometimes works , sometimes not). It's your "LUCK" . I figure it out: The path of the refinement file should be minimal, avoid spaces. May be it works:
Best Regards Ali |
April 23, 2012, 14:17 |
#9 |
Simon Pereira
Rep Power: 47 |
Hey Hybrid, I can see how it could seem that way. Most of the time, the Prism Params file is considered a temporary file (it is not when you run it batch or when you run with this refinement tool).
By default, temporary files are deleted automatically. You can turn off "clean up temporary files" under "settings => general". Best regards, Simon
July 12, 2012, 02:12 |
3D mesh generation in icemcfd
#10 |
nagalakshmi
Rep Power: 13 |
Sir,
Iam getting mesh by adding FLUID element. But the thing is only half of the body is generating mesh. Remaining half remaing as it is. When i don't use FLUID element then entire body is generating mesh. But some extra elements called CREATED MATERIAL are generated. I was sending images of the mesh. Please go through it. I have one more dbout what is the difference between Curv12 and tmp0012 curve. When i want trim surface through curve. When we select the curves first Cur12 get selected, then no trim takes place. We cannot delete the surface. In the next step when we select the curves then tmp0012 curves get selected . them the trim takes place and selected surface can be delated. Why? |
July 12, 2012, 02:19 |
#11 |
nagalakshmi
Rep Power: 13 |
Sir,
January 21, 2013, 08:24 |
#12 |
Smaras
Rep Power: 13 |
Didn't read the full post
Thanks Simon Regards, Smaras |
January 26, 2013, 09:08 |
#13 |
You can find all important ICEM documents here :
http://www.cfd-online.com/Forums/ans...efinement.html |
January 27, 2013, 22:45 |
#14 |
Ali
Rep Power: 16 |
Thanks FAR.
Is there any detailed tutorial for Multizone Meshing for external flows?
Best Regards Ali |
[snappyHexMesh] snappyHexMesh refinement regions ignored | guitarbren | OpenFOAM Meshing & Mesh Conversion | 2 | April 9, 2013 03:59 |
[snappyHexMesh] Boundary layer in a pipe | Clementhuon | OpenFOAM Meshing & Mesh Conversion | 6 | March 12, 2012 12:41 |
Cannot Start the post-processing tool of ICEM | Jean-Francois | Main CFD Forum | 1 | November 23, 2011 03:11 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
ICEM - Prism Tool Problem | carpe85 | CFX | 0 | February 10, 2009 12:25 |
