[GAMBIT] funny gambit
Old   April 14, 2012, 08:11
Default funny gambit
wwa
wwa's Avatar
wwa is on a distinguished road
hi all,
i just want to share with you this picture of a geometry i am working on.
it was created by boolean operations of several cylinders and final volume is virtual since i didn't manage to create real faces in this complex geometry. what is weird that one surface should be smooth and cylindrical but instead is going sharp at one point. there are no edges but it is visible when shaded or meshed. any comments why this occurs are appreciated.
Peter
wwa is offline   Reply With Quote
Old   April 30, 2012, 04:44
-mAx-'s Avatar
Maxime Perelli
First disable the mesh visibility and check if your topology is also affected. (enable shaded mode on)
Then try to make a split on the surface where you get this stuff
Just for perturbing the tology
gambit, mesh problem
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 06:29
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 12:39
Does Gambit has a maximum allowable grid number? spartan1516 ANSYS Meshing & Geometry 7 March 25, 2010 09:08
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 08:33
Problem starting Gambit ViHAR MALViYA FLUENT 0 November 10, 2006 10:26
