problems about GDO
Old   July 1, 2013, 08:05
Default problems about GDO
weixin shu
shuweixin is on a distinguished road
I am doing a optimization work about extrusion die. But I have a quetion now. I finished the design of experiments, but some design points failed to generate the geometry, so i want to delete these design pionts. So I change the Design of experiments type from central composite design to custom and delete the design points. It works and can update. But when I try to update the response surface, it comes error, the component response surface can not be updated. So what should I do?
shuweixin is offline   Reply With Quote
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[mesh manipulation] Problems with rotational cyclic boundaries TReviol OpenFOAM Meshing & Mesh Conversion 8 July 11, 2014 03:45
[ICEM] Flow channel meshing problems StefanG ANSYS Meshing & Geometry 19 May 15, 2012 06:44
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 05:44
Help required to solve Hydraulic related problems aero CFX 0 October 30, 2006 11:00
