Unchanged geometry post optmization
Old   February 6, 2014, 09:06
Default Unchanged geometry post optmization
criville'99 is on a distinguished road
I am trying to carry out a goal driven optimization on ANSYS workbench on a 2D airfoil. The problem is that when I finish the Optimization I go back to the geometry to view the 'optimized' airfoil, only to see that it is only the dimensions that have changed (I found this out when I drew a line over the dimensioned points, only to find out that the line is the same length as the 'pre-optimized' airfoil) and not the airfoil itself.
The input parameter in question is of the thickness of the airfoil (a dimension form the top to the bottom of the airfoil mid-section)
I have seen other optimization tutorials, were the parameter chosen is a function (revolve, extrusion etc…), I’m almost certain that the issue has to do with using the dimension itself as the parameter, but I have no idea what else to set as the parameter due to how the airfoil was designed (spline).
Things to note:
- - I had to design the airfoil on design modeler as I do not have the ‘add-in’ to use Solidworks (which will not update the geometry post optimization)
- - The airfoil is not a NACA profile, due to not being able to import from Solidworks or import from any txt files (would not work for me). It was designed using construction points, a spline and surface from sketches were created.
Any help would by highly appreciated
criville'99 is offline   Reply With Quote
[DesignModeler] Fill tool - grouping the faces of a complicated geometry? HeikkiT ANSYS Meshing & Geometry 8 July 20, 2016 07:37
CFX POST Geometry Scaling monkey1 CFX 2 July 11, 2013 04:01
[Workbench] Meshing and export mesh from STL geometry alerfreire ANSYS Meshing & Geometry 0 March 26, 2013 09:25
CFX Post - Inserting additional geometry Andrew CFX 2 April 18, 2007 08:27
CFX10 post, geometry parts not visible Claudia CFX 0 May 19, 2006 07:22
