Fluid-Structure-Interaction Ansys
Old   December 10, 2014, 08:59
Default Fluid-Structure-Interaction Ansys
Martinw is on a distinguished road
Hello all,
Im trying to simulate a Fluid-Structure-Interaction with Ansys Workbench 15.0. The fluid part with CFX and the structural part with ANSYS (Transient Structural).
The model has 3 parts:
1. The fluid domain, a tube with d=10mm and a length of 100mm
2. The Top Membrane, a Shell-Element (structural) with d=10mm and a thickness of 0.25mm
- the first Fluid Solid interface
- with a defined displacement on the center (a circle with d=1mm), only in Z-direction, longitudinal to the tube.
3. The Bottom Membrane, also a Shell-Element (structural) with d=10mm and a thickness of 0.25mm
- the second Fluid Solid interface
- it will be deformed due to the fluid forces.
So the tube is closed by the 2 Shell-Elements. The 2 Shells are deforming.
Analysis type: Transient
Total time: 10ms
Time steps: 1e-06s
My problem is the CFD Post and to visualize the displacement of the shells in a chart.
I would like to plot over time and for all time steps, the displacement of the shell in the Z- direction (longitudinal). I would like to have a plot of the displacement Z of transversal nodes.
I have tried it already with the definition of a 'Line' on the Shell and a Type 'XY' 'Chart'. For one single time step and for a small displacement I can plot it in a chart.
The problem with the 'Line' definition is that the line cannot follow large deformations of the shell, see the red line in the picture.
Have someone a better solution to plot a transversal nodes displacement of a surface? Or do somebody know the problem with my 'Line' definition?
If someone needs more information about the model, it would be a pleasure for me to describe it more in detail.
Thanks for the help!
Best regards,
Martin Wisniewski
Martinw is offline   Reply With Quote
cfx, chart, displacement, fluid solid interface, plot
Fluid structure interaction jnattia Main CFD Forum 25 May 21, 2015 09:16
[Help] Asking still about Fluid Structure Interaction setasena STAR-CCM+ 0 March 18, 2013 10:05
Fluid Structure Interaction shaan Main CFD Forum 1 February 20, 2012 13:26
Optimization or fluid structure interaction Steve_NTUA Main CFD Forum 9 August 29, 2006 03:40
FLUID STRUCTURE INTERACTION Javier FLUENT 1 October 14, 2004 13:42
