Home > Forums > Software User Forums > ANSYS
how to decrease stiffness ( slope of load deformation curve ) .. please help
Prev Previous Post   Next Post Next
Old   August 8, 2016, 13:03
Default how to decrease stiffness ( slope of load deformation curve ) .. please help
emad ogail
emadogail is on a distinguished road
I am trying to model a reinforced concrete slab supported on the four edges . the load is applied on square plate of 150 mm side length in the centre of the slab . The edges of slab are expected to lift up during the test . So a contact element of zero tension capability is used to model the boundary condition between the slab and the supporting plates.
The actual young modulus from experimental test is set in the ABDL mechanical ANSYS which equal to 20810 MPa
After solving the problem and plotting the load - central deflection curve .. I found that the stiffness ( slope of the curve ) was greater than the experimental one .. the problem is solved by reducing young modulus to 0.25 the actual young modulus.
But the solution is not acceptable to get the real behaviour.
Please help how to overcome that problem ? .. what are the different solutions to decrease stiffness without decreasing the young modulus?
emadogail is offline   Reply With Quote
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 10:49
meshing of a compound volume in GMSH shawn3531 OpenFOAM 4 March 12, 2015 10:45
mesh deformation - mesh stiffness alfonsojurado CFX 6 October 2, 2012 07:15
Mesh Stiffness Option for Mesh Deformation Ste_Lakey CFX 3 January 19, 2006 16:33
