Difference in Converge while using CFX and FLUENT |
February 19, 2017, 06:29 |
raunak jung pandey
Rep Power: 9 |
Hello everyone
I am writing this post because I am seeing a discrepancy in convergence while carrying out my simulation. So I want to discuss what could the reasons. I have a simple geometry using hexahedral mesh and having 2 million nodes. Velocity inlet and static pressure condition outlet is used. Reynolds number is 30000 and Mach number 0.11 My numerical setting in fluent k-e model with scalable wall functions Pressure based solver > First order upwind My simulation diverges in the following case. Even when the relaxation factors are reduced the simulation doesnt converges. When I used CFX using same mesh and same turbulence model. The solution easily converges to 10^-6 for all residuals. |
February 20, 2017, 19:41 |
Lucky
Rep Power: 66 |
Is the flow initialized the same way? With same values for both cases?
There are dozens of different settings between CFX and Fluent. The AMG parameters in Fluent have also changed from version to version. The pressure interpolation scheme in Fluent is second order. Unfortunately I've never used CFX to tell you what settings are different, even when they're similar. |
cfx, convergence check, fluent |
CFX vs. FLUENT | turbo | CFX | 4 | April 13, 2021 08:08 |
difference between CFX and fluent | rashmi | FLUENT | 17 | February 3, 2020 07:29 |
Difference between Fluent transitional model and CFX transitional model | Anna Tian | FLUENT | 2 | August 7, 2014 10:52 |
Difference between Fluent and CFX | safikhani_hamed | FLUENT | 1 | October 1, 2012 04:16 |
Difference between CFX and FLUENT | TypeSpeed | CFX | 3 | January 6, 2010 15:55 |
