Internal Circulation Inside of Chamber
Old   February 21, 2017, 15:48
Default Internal Circulation Inside of Chamber
Paul Aguirre
paul6030 is on a distinguished road
Greetings everyone,
I have a few questions that I want to ask.
I'm currently trying to model internal flow inside of a rectangular chamber.
The fluid is air and a fan is causing the circulation of the air. This fan is oriented 45 degrees from one of the faces at a specified distance. I'm not necessarily concerned about modeling the fan itself, but rather including the necessary boundary conditions to simulate the velocity or momentum being output by the fan
I wanted to ask what would the best route in modeling this fan/chamber be? Also, what should the boundary condition be for the "fan"?
Thanks for you help.
UPDATE:
Found solution to my problem
paul6030 is offline   Reply With Quote
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 03:21
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 22:38
Heater inside a closed chamber iamjnd FLUENT 0 December 21, 2015 01:56
Having problems setting up boundary conditions for paint chamber simulation shigua FLUENT 0 December 3, 2014 10:26
