Turbulence Intensity vs Reynolds number
Like Tree1Likes
  • 1 Post By jason580315
Old   February 26, 2017, 01:09
Default Turbulence Intensity vs Reynolds number
Jason
jason580315 is on a distinguished road
Hi everyone
I don't have too much background in fluid dynamics. From ANSYS user manual, turbulence intensity (I) of fully developed pipe flow is defined as :
I=0.16 *Re_dh^-1/8.
where Re_dh is the Reynolds number. It seems that turbulence intensity is inverse proportional to Reynolds number. We know that Reynolds number of laminar flow is much smaller than that of turbulent flow. But according to this equation, does that mean turbulence intensity of laminar flow is higher than that of turbulent flow? This doesn't make any sense because laminar flow should shouldn't have turbulence intensity or very low turbulence intensity. Which part I didn't understand correctly? Thanks.
BlnPhoenix likes this.
jason580315 is offline   Reply With Quote
Old   February 26, 2017, 03:00
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
I don't think that this formula is thought to be applicated for creeping flow or Re just beyond it.
In turbulent cases you have an effect: With lower Re the eddies take more room, because there is more time for expansion. An example is a well devloped Kármán vortex street. At much higher values of Re the turbulent area gets much more norrw, but with vortices containing more energy. A missile does't give a wide vortex street.
Thats the way I explain for me what the formula contains.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   March 1, 2017, 01:50
Jason
Thanks Uwe.
Old   March 1, 2017, 05:21
aziz
abdelaziz begag is on a distinguished road
hello every one.
I have a question about the flow regime, according to my bibliographic research I found that for low numbers of Reynolds i.e: 600- 1400,
The k-e turbulence model is introduced into the calculation, but the regime is laminar, can you please answer me.
abdelaziz begag is offline   Reply With Quote
decomposePar no field transfert Jeanp OpenFOAM Pre-Processing 3 June 18, 2022 12:01
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' BrendaEM OpenFOAM Meshing & Mesh Conversion 12 April 3, 2022 18:32
Displaying Turbulence Intensity in LES and creating a constant Turbulence Intensity Anwer FLUENT 1 August 8, 2016 16:59
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 18:45
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
