Fluid Structure Interaction of a Supersonic Nozzle - Importing Pressure |
June 5, 2017, 17:28 |
Vinayak Deshpande
Rep Power: 9 |
Dear Community,
I am performing a 3D FSI (fluid structure interaction) simulation on a supersonic nozzle in ANSYS Fluent. I have solved my CFD in Fluent, and wish to import the pressure load in Static Structural. The problem is that the imported Pressure in the FEA is pointing in the wrong direction Please see the attached image https://gyazo.com/e2ca918082959247cd7381947158c320 The pressure has to be pointing away from the nozzle centerline. In the imported pressure, it points toward the nozzle centerline, which is absurd, as the expansion pushes against the nozzle wall I am sure this has got something to do with my named selection, Is there an easy method to simply reverse the direction of the imported pressure? Thank you, |
cfd, fsi, nozzle, pressure, supersonic |
About one-way Fluid-Structure Interaction, form structure to fluid !? | xq712000 | ANSYS | 0 | July 15, 2016 09:40 |
Fluid Structure Interaction using icoFsiFoam Problems | lr103476 | OpenFOAM Running, Solving & CFD | 79 | August 7, 2014 09:30 |
fluid, solid, fluid structure interaction solvers | Maimouna | OpenFOAM | 0 | October 25, 2013 12:15 |
Fluid structure interaction of a flexible raft being towed through water | kennet | OpenFOAM Running, Solving & CFD | 0 | November 7, 2012 06:17 |
Fluid and Structure Interaction | MrAnderson | ANSYS Meshing & Geometry | 1 | October 8, 2010 16:04 |
