Using inlet mpi in parallel ANSYS fluent with AMD processors |
May 10, 2017, 08:36 |
Using intel mpi in parallel ANSYS fluent with AMD processors
meisam
Rep Power: 9 |
Hi
I set up and use successfully this tutorial (https://goo.gl/Ww6bkM) for clustering 2 machine to run the ansys fluent 17.2 in parallel mode. machine 1 (node1) is win server 2012 R2 64bit and machine 2 (node2) is win 8 64bit. both of them use Intel core i3 3.10 GHZ and 8GB memory. this tutorial use intel mpi for paralleling. Know i set it up for 2 machine with same OS like above, but with quad core AMD opteron processor 2378 2.4GHZ and 16 GB memory. When i run for parallel processing according the tutorial this error appear. error.jpg Is it possible that intel mpi dont compatible with this AMD processors for parallel run or other reason has been caused this? what should i do? thanks. Last edited by freebird; May 10, 2017 at 14:26. |
June 16, 2017, 09:04 |
meisam
Rep Power: 9 |
I find it. i changed all OS to win 8.1 and it was solved.
ansys, cluster computing, intel mpi, parallel fluent launch |
problem of running parallel Fluent on linux cluster | ivanbuz | FLUENT | 15 | September 23, 2017 19:12 |
Ansys SIG$ILL error | loth | ANSYS | 3 | December 24, 2015 05:31 |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 11:58 |
few quesions on ANSYS ICEMCFD and FLUENT | Prakash.Paudel | ANSYS | 0 | August 12, 2010 12:07 |
Fluent PARALLEL & MPI | Luca | FLUENT | 0 | May 13, 2006 03:04 |
