How to make changes in geometry and mesh from case file |
December 9, 2017, 08:14 |
Casper Pold
Rep Power: 11 |
Hi.
I have a cas file containing a project with an advanced mesh (Hexagonal mesh). I only have the cas file for this project, and nothing else. I would like to make a similar project but with a minor change in the geometry, and thus need to regenerate the mesh. I have the geometry file for the geometry with the minor change, but I would prefer not to make the mesh again for the new project. Is there a way to export the mesh and apply it on the new geometry? Or can I somehow extract the steps to create the mesh? |
case files, mesh, msh file |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
[snappyHexMesh] Problem with parallel run of snappyHexMesh | Lorenzo92 | OpenFOAM Meshing & Mesh Conversion | 5 | April 15, 2016 04:12 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
