Home > Forums > Software User Forums > ANSYS
Getting CFD Nusselt No to correlate with gnielinski theory
Like Tree1Likes
  • 1 Post By raghulvr
Old   January 28, 2018, 11:14
Post IMPORTANT PLEASE HELP!! Getting CFD Nusselt No to correlate with gnielinski theory
Jonathan
jonheb is on a distinguished road
Hi there
I am working on a project which is modelling smooth flow through a rectangular micro-channel. (The project does go further but for now this where I need help).
I am trying to obtain a Nusselt number that correlates with the use of Gnielinski theory but thus far I have had little success. I am trying to find htc by doing q/(Twall-Tbulk) but I don’t understand at what point I should take the temps and how I should. I have entered a heat flux BC.
I am using k omega SST model. I am using ANSYS fluent and their post.
If anymore info is needed just ask
jonheb is offline   Reply With Quote
Old   February 16, 2018, 20:33
Post
Rahul
raghulvr is on a distinguished road
For example, if you want to calculate Nusselt number at a surface, you need to find Twall- max temp at that point in a surface and Tmean-Avg temp at the surface
You can use your temperature contour to estimate at which point max temp occurs.Later, in CFD post you can create a point by specifying the co-ordinates of that point.
Then create a expression
maxVal(Temperature)@Location(in our case specify the point)
For mean temperature,
areaAve(Temperature)@Location(in our case specify the surface)
Cheers!
jonheb likes this.
raghulvr is offline   Reply With Quote
Old   March 2, 2018, 11:23
Jonathan
Hey there
I'm trying to get Nusselt for in the centre of the channel flow.
In Fluent I have been drawing a line across the wall and using surface integrals, area weighted average, wall temp for Tw
and then for the Tb I go into post and draw a plane at the same location of the line from above and then areaave temp plane.
I have a constant heat flux of 50000
The problem is these results aren't even close to what the Gnielinski correlation says I should be getting.
fluent
CFD Meshing Theory. Where can I read something more??? Stabum Main CFD Forum 4 October 26, 2012 06:48
is there any money in CFD? T Main CFD Forum 35 May 9, 2001 19:35
ASME CFD Symposium - Call for Papers Chris R. Kleijn Main CFD Forum 0 September 8, 1998 08:19
ASME CFD Symposium - Call for Papers Chris R. Kleijn Main CFD Forum 0 September 3, 1998 08:45
salary range Frank Muldoon Main CFD Forum 7 August 3, 1998 19:04
