March 20, 2018, 10:16 |
Chemkin-Pro API questions
Mingyuan Tao
Rep Power: 10 |
I have a general question about the usage of Chemkin-Pro API. In the reaction-design website it says to use the Chemkin-Pro API to get access to the libraries in CHEMKIN, in Linux system, we need to use the compiler of Intel Fortran Composer XE 2015 Update 2. In my linux system, the XE 2017 was installed before. When I tried running the example case it reported some errors during compilation. Did anyone before use the XE 2017 to run it successfully? I just want to make sure if the problem is because I use a newer but different compiler. Really appreciate if someone could give some hints! Best |
chemkin |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
how to add the ion reaction to the combustion mechanism in Chemkin Pro | dfzw_jwd | Main CFD Forum | 0 | December 1, 2016 03:30 |
[GAMBIT] Pro Engineer STEP import questions. | f_sizer | ANSYS Meshing & Geometry | 10 | August 2, 2010 01:17 |
Chemkin Pro and Chemkin CFD | Ekiguy | FLUENT | 0 | July 5, 2010 08:04 |
Prosurf to Proam problems, help please | William Wallace | Siemens | 11 | February 3, 2006 17:00 |
