April 14, 2018, 04:35 |
Exporting Chemkin Mechanism into fluent
sunil kumar
Rep Power: 10 |
Hello
how can I export a chemkin reduced mechanism into fluent for v 18.1. I have been able to reduce the mechanism however I can not see how to export the mechanism? |
April 14, 2018, 07:13 |
File --> Import --> CHEMKIN Mechanism where you can import gas phase, surface and transport database files in Fluent.. ^^ |
April 14, 2018, 08:33 |
sunil kumar
Rep Power: 10 |
after running the mechanism reduction do I need to export anything out of chemkin or is the project file what I import into fluent
February 9, 2021, 09:21 |
I am having problem how to import chemkin files in server with case file.
Rajesh
February 9, 2021, 10:57 |
Since you are loading only case file not data file, the reactions will be initiated from t=0s, so why don't you upload the chemkin files again to initialize the mechanism
chemkin surface mechanism format | Weiqiang Liu | FLUENT | 0 | April 6, 2018 10:00 |
Importing Chemkin Reaction into Fluent | skumar112 | FLUENT | 2 | March 22, 2018 21:56 |
Chemkin mechanism import of surface chemistry | Claud | FLUENT | 2 | August 5, 2013 08:03 |
exporting data from Fluent in batch mode without exporting entire design point | nnvoro | FLUENT | 5 | May 6, 2013 01:51 |
Chemkin CFD for Fluent | divyatman | FLUENT | 1 | July 20, 2009 13:44 |
