December 8, 2018, 09:44 |
Please help with imported pressure!
Rep Power: 7 |
I'm encountering an issue with importing pressures from ansys fluent to static. Essentially, I'm trying to figure out the effects of the pressure over an aircraft and see what the stresses and deflection are. I've imported the pressure by connecting the static module in workbench to the fluent module. The problem is, the mapped forces by static are larger than what they are supposed to be. The total lift force should be approx. 305N, which is the correct value from Fluent. But for some reason after importing into static and mapping onto the surface, the value is inflated to more than 500N. Refer to the attached file for a view of the setup. Any insights into this mystery are appreciated |
Same pressure gradient but different velocity field | TurbJet | Main CFD Forum | 22 | April 28, 2018 03:35 |
Periodic flow using Cyclic - comparison with Fluent | nusivares | OpenFOAM Running, Solving & CFD | 30 | December 12, 2017 05:35 |
Pressure loss Velocity coupling | CFXMUFFIN | CFX | 1 | February 6, 2016 04:43 |
Discharge of Pressure Vessel into Pipe with Regulator | gajowni2 | System Analysis | 0 | October 31, 2015 18:57 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
