October 13, 2019, 10:41 |
Heat-Fluid System Coupling
I am trying to set up a coupled system solution with heat exchange and natural convection. To this end I have modeled a square enclosure that is heated externally and I would like to solve the temperatures internally as those are affected by both the input heat and the natural convection occuring within the enclosure. I am trying to follow a similar tutorial I found on youtube https://www.youtube.com/watch?v=R_kdrg04_QQ However in my CFX model I don't get the system coupling as a heat transfer option. Additionally when I edit the system coupling I cannot set up a data transfer with my fluid domain as it only lists force as an output(no heat related stuff). Anyone has a clue on what is going on? |
ansys, cfx, heat transfer |
Simple piston movement in cylinder- fluid models | arun1994 | CFX | 4 | July 8, 2016 02:54 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
ansys cfx solver exit with return code 1!!!!! | mhabibnia | CFX | 7 | August 19, 2013 03:53 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
Heat Flux at Internal walls or Fluid Solid Interface | Mahi | CFX | 3 | October 1, 2012 02:18 |
