October 26, 2019, 05:55 |
shear stress on a surface
arash
Rep Power: 6 |
hello everyone,
i have a simple 2D problem (i attach a picture of the problem). left side is velocity-inlet and the right side is pressure-outlet. circle has a constant temperature and the fluid is only water. i want to add hydrophobic boundary condition to the wall(circle) then compare the shear stress on it with the hydrophilic one. how can i add this boundary condition in fluent?? pls help. |
November 5, 2019, 15:35 |
Erik
Rep Power: 23 |
I don't think hydrophobic/hydrophilic properties matter with single phase flow, do they? That has to due with multiphase, droplets and contact angles of those droplets I believe. If the entire volume is flooded with a single fluid, then there are no contact angles, the entire surface is covered.
fluent |
Shear stress boundary condition at free surface | yummigummi | OpenFOAM Programming & Development | 0 | September 2, 2019 06:34 |
Stress Graph & Shear Flow Graph & Displacement Graph in Tecplot or Paraview | semih60 | Tecplot | 0 | February 14, 2019 15:35 |
Export Wall Shear Stress Data | trooken | FLUENT | 6 | February 5, 2019 15:09 |
Shear Stress Calculation in the flow. | auburnuser | FLOW-3D | 11 | May 12, 2018 13:49 |
How can I plot area averaged wall shear stress variation with time over a surface? | Gourabc | FLUENT | 0 | January 31, 2017 23:56 |
