Automation of a Procedure
Old   December 8, 2019, 04:19
Default Automation of a Procedure
Safasml is on a distinguished road
Hi all.
I have a project in which I should create a geometry, mesh it and solve the flow with a solver such as fluent. Then compare the results with some specified data and then correct the geometry, mesh it and solve it again. This process should be repeated over and over until the results get the same as the specified data. What is the best way to do this procedure using ANSYS?
I tried coupling MATLAB with MAPDL. However, since the project relates to fluid mechanics, I should use FLOTRAN and in ANSYS 15 and later, this option has been deleted, I think so. So, using MAPDL is not preferable.
Safasml is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh procedure and informations Astan OpenFOAM Meshing & Mesh Conversion 0 June 11, 2018 05:55
An efficient procedure to solve many design points for flow with reaction in fluent jumaah FLUENT 4 May 4, 2017 20:10
Dynamic SGS model procedure in Large eddy simulation mrf6166 Main CFD Forum 39 November 25, 2016 14:13
[ICEM] Procedure : how to mesh correctly two semicircles in an air flow ? eeesprit ANSYS Meshing & Geometry 2 April 10, 2011 15:14
Calculation of Averages in lesInterFoam Erroneous Procedure ngj OpenFOAM Bugs 6 April 15, 2008 13:21
