August 12, 2020, 10:06 |
IcePak temperature continues to drop
Peter Hagan
Rep Power: 14 |
Hi All,
I have not posted often, but I do frequent the forum. Thanks for all the great info! I have an issue with my icepak simulation. While the residuals seemingly converge, my temperature monitor continues to decrease with iterations, regardless of how many iterations I perform. It decreases at a linear rate. I have an adiabatic cabinet with a rack (geometry macro) heat source placed in the center of it. Instead of using the CRAC macro, which only allows an intake temperature, I am using a recirculating opening which allows a heat input thermal condition. In this case I am pulling -15000BTU/h from the domain. This seems to be where my issue is, because if I use a CRAC macro and set the intake temperature, the temperature plots become level. Any help would be appreciated. Thanks! |
August 12, 2020, 11:37 |
Peter Hagan
Rep Power: 14 |
An update on my issue.
It makes more sense to me now that the temperature would continuously decrease in an adiabatic system with the given heat generation inputs. I added wall material and an external temperature and my solution converges more quickly with a steady temperature. |
Unphysical temperature drop when using dynamic mesh | peyman.havaej | OpenFOAM Running, Solving & CFD | 1 | June 24, 2020 08:35 |
High temperature methane+air | Peter | FLUENT | 5 | January 26, 2009 18:04 |
Flotherm-Icepak comparison for electronic cooling | Masoud Ameli | FLUENT | 0 | February 28, 2005 09:00 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 00:07 |
Temperature in vessel during throttling process | Astrid | Main CFD Forum | 2 | January 31, 2001 02:34 |
